Cycles not using both NUMA Nodes on Dual Xeon Setup #61535
Reference: blender/blender#61535
Operating system: Windows 7 pro 64bit
CPU: 2*Intel Xeon e5-2696v3
Broken: 2.80.xx
Worked: 2.79
When i render, Cycles wont use both NUMA Nodes (or CPU Groups) but only one. Even if i change from "Auto detect" to "Fixed" and fill in "72" inside the Performance-Tab, it spawns 72 Buckets but will actually use only 36 CPU Threads. While the auto detect option also didnt work in 2.79, the "fixed" parameter worked and used all 72 Threads for rendering.
Since this occurs only on this machine and not my second one (only 48 threads), my guess is that this is an issue with Windows CPU Grouping that will split everything that exceeds 64 Threads into Groups. If a software is not aware of this, they can only use one NUMA Node (or cpu Group). In my case that would be exactly 36 Threads.
Added subscriber: @Archimondro
#66549 was marked as duplicate of this issue
Added subscriber: @brecht
Which exact 2.79 and 2.80 version are you testing (date from the splash screen)?
Sorry,
Dosent work with: 2.80.44 (2019-02-07)
Works with : 2.79.6 (2018-11-09)
Added subscriber: @bazuka
Should be fixed by
8f1a558
.Can confirm that it is working again on my dual e5-2696v3 machine. Autodetect will (as before) only show one node (36 threads in my case) but if i put in 72 manually, it uses all cores/threads. Thanks for fixing!
