Multiple UV maps editing not working properly
Operating system: Windows 10 PRO
Graphics card: Gigabyte Radeon RX 570 8GB
Broken:
2.80, 0d86259fc8a3, blender2.8, 2019-02-16
Having selected multiple objects and adding a new UV map adds new UV map only to the active object.
Also when selecting an UV map in the UV editor on multiple objects at once when objects have different UV map active cause to swap the active UV map to other on every object, but not setting the proper UV map.
Add second UV map to multiple objects selected - new UV map will be added only to active object.
On one object change the active UV map, then select all objects in the scene and go to UV edit. In the UV editor change active UV map - active UV map will change on all objects based on what UV map was set as active before or active UV map will change only on active one.
Brecht Van Lommel (brecht) closed this task as Archived.
The properties editor only works on a single active object, not multiple objects. There is T54862: Multi-Object Properties Editing to make that possible, but the current behavior is intentional.
