Image as Plane cloth error #61640
Reference: blender/blender#61640
Operating system: Windows 10 64
Graphics card: Nvidia GTX1060Q
blender-2.80.0-git.0f135f80f271-windows64
Image as Plane in cloth simulation generates distorted mesh while Self Collision is enabled
( simulation will run correctly)
Added subscriber: @iKeyborg
Added subscriber: @StephenSwaney
Got a .blend for us?
IMAGE_PLANE_CLOTH.blend
Please open and run simulation
Please disable Self Collision, It will work.
Added subscriber: @nacioss
Yeah, it does get weird results in your blend.
However, i tried with the latest build of today's 2019-02-18 and it seems to work properly now:
I have downloaded blender-2.80.0-git.7d792976e100-windows64 (2019-02-18)
It still doesn't work.
Please don't disable Self Collision and click play.
Added subscriber: @ZedDB
If I open that fine and play the animation, I can see the same problem.
However, if I disable self collision AND then re-enable it works.
Does this happen for you too?
If it solves it for you, can you still make this happen when recreating the scene?
I suspect this is something that has been fixed but blend files that were saved when this bug was in is still broken until you toggle the settings.
Unfortunately, It doesn't work even after toggling self collision.
I created a cloth model from scratch in 2.18.2019 Blender. I see the same problem. Can it be Preference or Registry corruption?
If
Load Factory Settings
and save thenSave Startup file
and save user preferences. Can you still reproduce this?I did everything you suggested with today's build (02.19.2019).
I got a new piece of information. If I create a plane from image and subdivide it to 20x20 mesh, it works. If I divide the image as plane in to 50x50 mesh it doesn't work. If I subdivide 20x20 mesh once it doesn't work as well.
Does it help if you increase the number of quality steps of the simulation to 20 or so?
Quality steps don't help. Max working subdivision factor is 25x25.
26x26 doesn't nork
I installed 2/20/2019 version on a different old laptop never used for blender.
I does same thing. Do you import image as plane? What is difference between plane from Add Mesh and imported image?
I don't think this is an add plane issue. It is just a general stability issue with simulations.
If you add a normal plane it is 2x2meters. The import as plane defaults to 1m
The add image as plane makes the imported plane rectangular (unless the image size is square).
What happens here is that the solver for the cloth sim has a hard time to find a solution to the simulation.
This case it hard because of the smaller size and that you have pinned all edge verts on one side.
Additionally the plane is collapsing in on itself.
In the example you attached, the distance between the verts on the flag horizonatally is ~0.02m. In the self collision settings, you can see that the amount of distance you want to keep between the self colliding verts are 0.015m. As you can guess this leaves very little space for the flag to have the verts move. So you can set it to 0.001m instead and it should be better.
Can you confirm that changing the value to 0.001m works for you?
Sebastian,
Now it works like a charm.
I think little diagnostic or error message if self-collision distance is bigger than minimum mesh cell would be helpful to avoid some simulation errors.
Looks like only self-collision distance can prevent from self-penetration: not too big to keep simulation successful and not too small to prevent self- penetration. Is there another way to prevent self-penetration?
Sergey
Self-collision is the only way to prevent it falling through itself in this case.
There could perhaps be some kind of self diagnostics as you said, however that is move of a feature request (so not something for this bug tracker).
There have been talks about replacing the cloth and particle system in the future. So these areas are currently not worked on that much (as they will probably be replaced).
