Compositing node Vector -> Normalize inputs and outputs scalars not vectors #61875
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#61875
Operating system: Ubuntu 18:04
Broken: 2.8 from February 4, 2019
The Vector -> Normalize node, visible in the compositor, takes/returns scalars (numbers denoted by a grey dot) instead of vectors (two values denoted by a blue dot). It is impossible to normalize scalars (unless you just set them to equal 1), so this shouldn't even be an option. I'm guessing this is a cosmetic issue.
Open the compositor, enable "use nodes," add a Vector -> Normalize node
Added subscriber: @finnb
The actual problem here seems to be the documentation, not the implementation.
In the code it says:
Normalize single channel, useful for z buffer
(https://developer.blender.org/diffusion/B/browse/master/source/blender/nodes/composite/nodes/node_composite_normalize.c$28).While the manual explains something very different (https://docs.blender.org/manual/en/latest/compositing/types/vector/normalize.html).
This issue was referenced by 4574
@JacquesLucke Now I'm wondering why this node is in the "Vector" category, and that actually applies to most of the nodes there. These nodes, except vector curves, really stretch the meaning of "vector."
Added subscriber: @WilliamReynish
@finnb, you are right. That does not really make sense.
@WilliamReynish, where should this be?
As @finnb points out, that could be argued for almost all the nodes in the Vector category.
We could put them inside the Converter category? Or we could add a new category called 'Values' or something like that?
Although if we use the logic of the main input or output socket, the Vector category would be almost empty.
Hmmm, I'm not sure... Maybe this should be discussed in a design task.
The vector category wouldn't be almost empty if a true "normalize" node was added. The current "normalize" node could be renamed "normalize channel."
Also, where can I find "design tasks?"
