bpy.data.* name lookups are no longer reliable #61998
Reference: blender/blender#61998
The following script asserts on the last line when it shouldn't, caused by
456e3f00e0
Added subscriber: @ideasman42
Added subscriber: @mont29
Yes, currently this will break. If people find it fancy to use names like
F Blabla
for their IDs, sorry but I’d consider this very odd corner case that should not happen in real life. Much more unlikely than having aBlabla
local object together with aBlabla
linked one, and not being able to distinguish them in the UI ID selectors (as was the case before). You can also use completely broken meshes with booleans and claim they are not working. Or you can name your boneFoo.R
and the next oneFoo.L
, enable mirror edit, and say that it breaks your armature. etc. etc.Now, background for that behavior: UI widget (ID pointer drop-down selector) uses UI string to also lookup for the ID. So you can either cope with that on the generic ID lookup system, or you can go into that nightmarish UI code to make it properly separate ID identifier from UI name, store both, and return proper full qualified ID identifier instead of UI name as its value… If you feel like doing that, be my guest.
Sure, there are areas in Blender which are in a bad state, but this isn't reason to add more. We managed for years without this kind of hack.
Really this isn't acceptable - name look-ups must be fast and accurate, the UI must work around this. Would consider having a separate UI identifier less hackish/error prone.
Related discussion: blender/blender-addons#58641
Added subscriber: @brecht
Please revert
4669c3692c
and456e3f00e0
, and then we can add a better implementation after that.Issues like blender/blender-addons#58641, #58917 are not at all obvious for Python API users or even Blender developers, this will likely cause more bugs in the future.
Removed subscriber: @mont29
Reverted. People who like UI code can go fixing that mess the proper way if they want.
