Support mp4 file format output for 'blender_video_chunks' job type
Closed, ResolvedPublicTO DO
Unfortunately .mkv is not well supported by some macOS apps.
In order to share the file, we often need a conversion from .mkv to .mp4. A simple container change using ffmpeg does not seem to work correctly (file does not open in QuickTime, lags in other software, etc.) so we actually have to re-encode the file, which is an error-prone and time consuming process.
For the sake of interoperability, it would be very nice to support the .mp4 container as output of the blender_video_chunks job type. The major drawback of the .mp4 is the loss of any metadata that .mkv could provide (once we will start taking advantage of that) but I would consider that acceptable.
Thanks for your consideration!
Francesco Siddi (fsiddi) lowered the priority of this task from 90 to High.Mar 4 2019, 7:09 PM
Francesco Siddi (fsiddi) created this task.
Sybren A. Stüvel (sybren) changed the task status from Unknown Status to Resolved.EditedMar 6 2019, 1:39 PM
Implemented in ff9624d4f37ab035c27d1d5c59c654f88656ad49 (Blender Cloud add-on) and 5f96d2e50b852dcc1bd350dafc72dea67e02983e (Flamenco Server).
You can influence the output container type by setting it in the Encoding panel in Blender.
