Import rigify character from 2.79 into 2.80 yields no shapes #62284
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
6 Participants
Reference: blender/blender-addons#62284
Operating system: MacOS 10.14.3
Graphics card: Radeon Pro 575
Broken: blender-2.80.0-git20190306.3fc7d51ed3d3-x86_64
(example: 2.79b release)
When I import a rigify rigged character from 2.79b, all the shapes are gone. The only way to retrieve the shapes is to go through the rig, bone by bone, in the outliner and turn on wireframe in the Bone tab->Viewport Display.
In blender 2.79b, add metarig. Then Generate a rig. Save out file. Read file into blender 2.80. No shapes
Added subscriber: @NeilRichmond
Added subscriber: @deusexvagina
I have noticed the same error and was not aware of this workaround. I found that changing the armature to stick rather than shapes results in a usable rig that can at least be worked with and it's much faster than changing single bones because it works on armature level. Still, it is an annoying bug for me as well.
Added subscriber: @icappiello
This should be handled by blender itself onload. All armatures using shapes are affected. it's not an add-on related bug.
@NeilRichmond you should probably change the tags or create a new task if you want this to be solved quickly.
Added subscriber: @hscharitzer
This issue was referenced by blender/blender@e583e86a9a
Thank you for the fix!
Please excuse the ignorant question: when will this be in the beta build?
