Blender 2.80.48 Video Editing Adding Scenes that are selected in the outliner bug/behavior? #62604
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
5 Participants
Reference: blender/blender-manual#62604
Operating system: Windows 10
Graphics card: Intel HD 4000/4400
2.80.48
blender-2.80.0-git.55e79d8f36c6-windows64
Adding scenes in video editing tab seems to be connected to the scene that is selected in the outliner, in a way that it does not allow that scene to be added (does not appear in the Add pop out). The way around this that works for me, is to create a dummy scene in the outliner and select it, so that the other non-selected scenes can be put into the video editing tracks.
In the help doc:
https://docs.blender.org/manual/nb/dev/editors/vse/sequencer/strips/scene.html
it is mentioned that adding the scene that is selected is supported, even though it is not recommended to avoid confusion.
steps in video linked below:
https://youtu.be/haFYVD5l9Fc
Added subscriber: @blendaluva
Added subscriber: @iss
Thanks for pointing this out. Adding scene to itself is not supported for quite a while.
The information in the docs is outdated.
Added subscriber: @ZedDB
@iss I guess I can mark this as confirmed then?
Added subscriber: @Blendify
Task is more or less invalid, but docs should be fixed so I guess..
I can not make those changes (I think)
@Blendify may be for you?
Added subscriber: @brecht
@iss, you actually have commit rights to the documentation repository (username and password and are the same as for logging into this site).
Is it this one?
https://developer.blender.org/diffusion/BM/
Looks like SVN, so I will have to setup that.
Yes, there's some instructions here:
https://docs.blender.org/manual/en/dev/about/contribute/index.html
I can also commit this fix quick, just saying you can if you want to.
This issue was referenced by 4595
Thanks, I was busy this week haven't got even to respond to you.
