Most edit mode tools do not work #62608
Closed
opened 2019-03-15 12:17:59 +01:00 by Sebastian Parborg · 9 comments
Operating system: Linux-5.0.2-gentoo-x86_64-AMD_FX-tm-8120_Eight-Core_Processor-with-gentoo-2.6 64 Bits
Graphics card: AMD Radeon R9 200 Series (HAWAII, DRM 3.27.0, 5.0.2-gentoo, LLVM 9.0.0) X.Org 4.5 (Core Profile) Mesa 19.1.0-devel (git-5475434fa6)
Broken: version: 2.80 (sub 49), branch: master (modified), commit date: 2019-03-15 09:35, hash: e775ad6c1b
Most edit mode tools like inset, bevel and so one does not work anymore.
If you use right click select, left click will only move the 3D cursor with most edit mode tools.
(Also broken with left click select)
  1. Open the default cube scene
  2. Go into edit mode on the cube
  3. Try to use the inset tool or loop cut tool from the tool bar
  4. They do not work
@WilliamReynish has confirmed this as well.
**System Information** Operating system: Linux-5.0.2-gentoo-x86_64-AMD_FX-tm-8120_Eight-Core_Processor-with-gentoo-2.6 64 Bits Graphics card: AMD Radeon R9 200 Series (HAWAII, DRM 3.27.0, 5.0.2-gentoo, LLVM 9.0.0) X.Org 4.5 (Core Profile) Mesa 19.1.0-devel (git-5475434fa6) **Blender Version** Broken: version: 2.80 (sub 49), branch: master (modified), commit date: 2019-03-15 09:35, hash: `e775ad6c1b` Worked: (optional) **Short description of error** Most edit mode tools like inset, bevel and so one does not work anymore. If you use right click select, left click will only move the 3D cursor with most edit mode tools. (Also broken with left click select) **Exact steps for others to reproduce the error** 1. Open the default cube scene 2. Go into edit mode on the cube 3. Try to use the inset tool or loop cut tool from the tool bar 4. They do not work @WilliamReynish has confirmed this as well.
Author
Member
Added subscribers: @WilliamReynish, @ZedDB
Campbell Barton was assigned by Sebastian Parborg 2019-03-15 12:18:27 +01:00
It seems like the transform tools work normally, as do tools that make use of gizmos, such as Extrude. But, all the Mesh Edit and Curve Edit tools which rely on clicking and dragging in the viewport fail.
Added subscriber: @RainerTrummer
Transform Tool is also affected, but it is less visible. If you set Drag Action to None it still transforms on drag.
Transform Tool is also affected, but it is less visible. If you set `Drag Action` to `None` it still transforms on drag.
Poly Build Tool also does nothing when you try to use it
This issue was referenced by fb4bb61155
This issue was referenced by fb4bb611559bdb9d7f7b5206a812965c9223c0a9
Added subscriber: @brecht
@ideasman42, I committed a quick fix so we don't get lots of reports about this.
5 Participants
Reference: blender/blender#62608
