ID user decrement error, likely related to custom material PointerProperty #62643
Closed
opened 2019-03-16 11:56:13 +01:00 by MACHIN3 · 5 comments
Operating system: Linux-4.13.10-041310-generic-x86_64-with-debian-stretch-sid 64 Bits
Graphics card: GeForce GTX 1050/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 390.67
Broken: version: 2.80 (sub 49), branch: blender2.7, commit date: 2019-03-15 23:51, hash: 3600bb79d0
Worked: -
Changing any material property on the material of the selected object in the attached blend, causes the terminal to print these errors:
ERROR (bke.library): /home/sources/buildbot-x86_64-slave/linux_glibc224_x86_64_cmake/blender.git/source/blender/blenkernel/intern/library.c:242 id_us_min: ID user decrement error: MAplastic.red (from '[Main]'): 0 <= 0
Interestingly, the error occurs only when the material properties panel is open. so it may be related to the preview icon?
The file was saved with a custom defined PointerProperty, which is currently pointing to the material plastic.red.
You can register the property from the text editor in the blend, but it's not even necessary.
If you do register the property, you can set it to None and the error will be gone.
This error used to be a Warning a while ago.
I've been getting it since at least December, when I started using this PointerProperty.
  • open the attached blend
  • change the emission strength in the node editor, watch the terminal
  • switch to the materials workspace or switch away from the material properties and change the value again, nothing will happen
  • the blue material has a PointerProperty at material.DM.matchedmaterialto, pointing to the plastic.red material
  • you can register it by running the script in the text editor, but the error occurs even without it being registered
  • if registered. set it to None and the error will be gone
Video demo
ID_user_decrement_error.blend
**System Information** Operating system: Linux-4.13.10-041310-generic-x86_64-with-debian-stretch-sid 64 Bits Graphics card: GeForce GTX 1050/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 390.67 **Blender Version** Broken: version: 2.80 (sub 49), branch: blender2.7, commit date: 2019-03-15 23:51, hash: `3600bb79d0` Worked: - **Short description of error** Changing any material property on the material of the selected object in the attached blend, causes the terminal to print these errors: ``` ERROR (bke.library): /home/sources/buildbot-x86_64-slave/linux_glibc224_x86_64_cmake/blender.git/source/blender/blenkernel/intern/library.c:242 id_us_min: ID user decrement error: MAplastic.red (from '[Main]'): 0 <= 0 ``` Interestingly, the error occurs only when the material properties panel is open. so it may be related to the preview icon? The file was saved with a custom defined PointerProperty, which is currently pointing to the material `plastic.red`. You can register the property from the text editor in the blend, but it's not even necessary. If you do register the property, you can set it to None and the error will be gone. This error used to be a Warning a while ago. I've been getting it since at least December, when I started using this PointerProperty. **Exact steps for others to reproduce the error** * open the attached blend * change the emission strength in the node editor, watch the terminal * switch to the materials workspace or switch away from the material properties and change the value again, nothing will happen * the blue material has a PointerProperty at `material.DM.matchedmaterialto`, pointing to the `plastic.red` material * you can register it by running the script in the text editor, but the error occurs even without it being registered * if registered. set it to None and the error will be gone [Video demo ](https://www.youtube.com/watch?v=1eqamzYCVlI) [ID_user_decrement_error.blend](https://archive.blender.org/developer/F6833965/ID_user_decrement_error.blend)
Author
Added subscriber: @MACHIN3
Added subscriber: @mont29
Bastien Montagne self-assigned this 2019-03-16 22:34:07 +01:00
Confirmed.
Confirmed.
This issue was referenced by 606f3c74d3
This issue was referenced by 606f3c74d36bbbe6b7e3aeae962176a89355a552
Reference: blender/blender#62643
