I can not install Landscape addon #62714
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#62714
Operating system: Ubuntu Studio 18.10
Graphics card:
Broken: 2.79-2.79b-2.79rc1
(example: 2.79b release)
I can not install the addon A.N.T. Landscape in none of the versions, I attached the error image, I do not know where Blender saves the log errors
Added subscriber: @Calero
Added subscriber: @WilliamReynish
Are you installing the 2.8 version of the addon or an older version?
Hello, I have tried in all the 2.79, I have a project in which I had used the Addon, but now I can not use it, the errors that I show in the capture come out. In the preferences it appears as if it were installed but it does not appear in the menus, so it is deactivated and when I try to activate it the problem arises.
In previous versions it is activated, but when creating a landscape, many of the options to modify it do not appear.
I hope you understand what I explain, because I do not know much English and I have to use a translator.
Thank you
Hello,
I managed to fix it, I deleted everything I had in the personal folder /home/user/.config/blender/2.79/scripts/addons I opened Blender and I loaded the Addon again, it seems that everything works fine.
A saudo and thank you
