Subdivide a hair segment causes the high light to appear at the wrong place #62730
6 Participants
Reference: blender/blender#62730
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 418.81
Broken: version: 2.80 (sub 50), branch: master, commit date: 2019-03-18 20:40, hash:
ce09b93955
Worked:
Subdivide the entire hair does not cause the problem, the highlight appear at the correct place.
In Particle edit mode, subdivide a segment of the hair will cause the selection highlight appear at the wrong part.
With the default cube, add a hair system, reduce the number to 1, switch to particle edit mode, select 2 connecting vertices, then subdivide.
Now if you select an individual vertex, the highlight appear at the wrong place
Added subscriber: @ssendam
Added subscribers: @Sergey, @ZedDB
@Sergey as always, feel free to reassign if this is not for you.
@ZedDB, not sure i am properly understanding the issue here (could be multiple ones). Mind testing the patch? fix_T62730.patch
@Sergey the issue is that the highlight on the line seem to be centered around the wrong center point.
(However, your patch fixed a refresh issue, the hair geometry now updates after the subdiv command. So be sure to include it too)
Correctly centered before subdivide:
Shifted highlight after subdivide:
Test file:
hair_vert_sub.blend
This highlight offset issue also seems to happen in 2.79 btw.
In Blender 2.79, the wrong highlight is a different issue, it is because of the low path steps, regardless of subdivide or not. Increase the path steps will solve the issue. This also happens in 2.8.
If you set the hair segments to 7 and path steps to 2, you can see it very clearly in both 2.79 and 2.8.
The subdivide issue is different, increasing the path steps doesn't help
Added subscriber: @fclem
@fclem , as far as i know the highlight is handled by the drawing code, which i am not familiar with. The annoying part is that the highlight is somewhat decoupled from control points, but think it should be possible to have it behave similar to 2.79.
Mind having a look?
P.S. I've committed my fix for the refresh issue.
Looks like the drawing code expects that the points are uniformly spaced along the hair strand.
This issue was referenced by
b2034c6ba2
