Text objects no-longer are filled by default #62866
5 Participants
Reference: blender/blender#62866
Graphics card: GeForce GTX 1050 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 419.35
Broken: version: 2.80 (sub 51), branch: master (modified), commit date: 2019-03-22 19:36, hash:
967364dc3e
Worked: Pre https://developer.blender.org/rBbc5b0f7a091c3955263701be8c858fd56f8ba59f patch
Text objects no-longer are full as of the change to default fill mode to full (Can't help but feel this is my fault) for 3D curves this has the opposite affect on 2D curves.
As far as I can tell for some reason blender's curve system treats the back and front flags on curves as what sides to cull on 3D curves. While 2D curves use the same flag to determine what sides to fill. I'm not sure if the correct approach would be to fix the add text function to create a curve with these flags enabled or if this should be considered a bigger issue to cleanup for consistency.
Add a Text object...
Added subscriber: @KenzieMac130
Added subscriber: @WilliamReynish
This is an unintended consequence of the fact that curves now default to Full fill mode, which doesn't exist for text objects, and so it falls back to None.
Either we could override the default for text objects, or make it so it falls back to Both?
I'd vote to override the defaults for text since it seems like the better short term solution. It should keep the best of both worlds (full curves and full text). Its just curious that blender has this discrepancy in the meaning behind those flags in 2D and 3D, I'm pretty sure that decision was made long ago and might be worth looking into cleaning up that inconsistency in a future task. For now since I was the one who authored the original change I'm going to try to fix this one by overriding the defaults for text objects and I'll post the diff if that's okay.
Edit: actually I'm considering just moving where curves get set to default in the editcurve_add.c since it seem's that some older code that uses curves might make some assumptions about the flags on curve object (this turned out to be a bigger mess than I initially anticipated) Either way I'll try to get it fixed.
After a long search through the code I think I've come across the easiest solution.
The diff file can be found here if anyone can approve it, thanks: https://developer.blender.org/D4581
Added subscriber: @LazyDodo
Changed status from 'Resolved' to: 'Open'
Bugs should not be closed until a patch has been committed.
Apologies, I'm new to this.
This issue was referenced by
7bfd3130fb
