MeasureIt addon not loading. #63027
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#63027
Operating system: Darwin-17.4.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon RX 580 OpenGL Engine ATI Technologies Inc. 4.1 ATI-1.60.26
Broken: version: 2.80 - MacOx builds for March 26 and 27th.
Addon not loading. Attempt to de-select and re-select addon in preferences and the following error ocures
ValueError: register_class(...): already registered as a subclass
Added subscriber: @DiveMeCarzy
Steps to reporduce error
Open blender
Add cube
Go to use measure it. measureit not there.
Go to blender preferences - addons
click to disable addon
click to enable addon
Error code occures
see error code.
Addons not loading Eric.blend
Here is a list of errors from other addons also not working, Some of them are not included with blender but I have added them for you interest. Also note that this problem is not occuring for Mac build 24 March and before. When I go back the build for March 24 everything works fine.
bpy.ops.mesh.primitive_cube_add(size=2, view_align=False, enter_editmode=False, location=(0, 0, 0))
bpy.ops.object.editmode_toggle()
bpy.ops.machin3.face_mode()
bpy.ops.mesh.extrude_region_move(MESH_OT_extrude_region={"use_normal_flip":False, "mirror":False}, TRANSFORM_OT_translate={"value":(0, 0, 1.82467), "orient_type":'NORMAL', "orient_matrix":((0, 1, 0), (0, 0, 1), (1, 0, 0)), "orient_matrix_type":'NORMAL', "constraint_axis":(False, False, True), "mirror":False, "proportional":'DISABLED', "proportional_edit_falloff":'SMOOTH', "proportional_size":1, "snap":False, "snap_target":'CLOSEST', "snap_point":(0, 0, 0), "snap_align":False, "snap_normal":(0, 0, 0), "gpencil_strokes":False, "cursor_transform":False, "texture_space":False, "remove_on_cancel":False, "release_confirm":False, "use_accurate":False})
bpy.ops.mesh.extrude_region_move(MESH_OT_extrude_region={"use_normal_flip":False, "mirror":False}, TRANSFORM_OT_translate={"value":(0, 0, 2.43659), "orient_type":'NORMAL', "orient_matrix":((0, 1, 0), (0, 0, 1), (1, 0, 0)), "orient_matrix_type":'NORMAL', "constraint_axis":(False, False, True), "mirror":False, "proportional":'DISABLED', "proportional_edit_falloff":'SMOOTH', "proportional_size":1, "snap":False, "snap_target":'CLOSEST', "snap_point":(0, 0, 0), "snap_align":False, "snap_normal":(0, 0, 0), "gpencil_strokes":False, "cursor_transform":False, "texture_space":False, "remove_on_cancel":False, "release_confirm":False, "use_accurate":False})
bpy.ops.mesh.extrude_region_move(MESH_OT_extrude_region={"use_normal_flip":False, "mirror":False}, TRANSFORM_OT_translate={"value":(0, 0, 2.27959), "orient_type":'NORMAL', "orient_matrix":((-1, 0, 0), (-0, -0, -1), (0, -1, 0)), "orient_matrix_type":'NORMAL', "constraint_axis":(False, False, True), "mirror":False, "proportional":'DISABLED', "proportional_edit_falloff":'SMOOTH', "proportional_size":1, "snap":False, "snap_target":'CLOSEST', "snap_point":(0, 0, 0), "snap_align":False, "snap_normal":(0, 0, 0), "gpencil_strokes":False, "cursor_transform":False, "texture_space":False, "remove_on_cancel":False, "release_confirm":False, "use_accurate":False})
bpy.ops.mesh.extrude_region_move(MESH_OT_extrude_region={"use_normal_flip":False, "mirror":False}, TRANSFORM_OT_translate={"value":(0, 0, 2.30267), "orient_type":'NORMAL', "orient_matrix":((-1, 0, 0), (-0, -0, -1), (0, -1, 0)), "orient_matrix_type":'NORMAL', "constraint_axis":(False, False, True), "mirror":False, "proportional":'DISABLED', "proportional_edit_falloff":'SMOOTH', "proportional_size":1, "snap":False, "snap_target":'CLOSEST', "snap_point":(0, 0, 0), "snap_align":False, "snap_normal":(0, 0, 0), "gpencil_strokes":False, "cursor_transform":False, "texture_space":False, "remove_on_cancel":False, "release_confirm":False, "use_accurate":False})
bpy.ops.mesh.extrude_region_move(MESH_OT_extrude_region={"use_normal_flip":False, "mirror":False}, TRANSFORM_OT_translate={"value":(0, 0, 6.48561), "orient_type":'NORMAL', "orient_matrix":((0, 0, 1), (0, -1, 0), (1, 0, 0)), "orient_matrix_type":'NORMAL', "constraint_axis":(False, False, True), "mirror":False, "proportional":'DISABLED', "proportional_edit_falloff":'SMOOTH', "proportional_size":1, "snap":False, "snap_target":'CLOSEST', "snap_point":(0, 0, 0), "snap_align":False, "snap_normal":(0, 0, 0), "gpencil_strokes":False, "cursor_transform":False, "texture_space":False, "remove_on_cancel":False, "release_confirm":False, "use_accurate":False})
bpy.ops.mesh.extrude_region_move(MESH_OT_extrude_region={"use_normal_flip":False, "mirror":False}, TRANSFORM_OT_translate={"value":(0, 0, 2.47653), "orient_type":'NORMAL', "orient_matrix":((0, 0, 1), (0, -1, 0), (1, 0, 0)), "orient_matrix_type":'NORMAL', "constraint_axis":(False, False, True), "mirror":False, "proportional":'DISABLED', "proportional_edit_falloff":'SMOOTH', "proportional_size":1, "snap":False, "snap_target":'CLOSEST', "snap_point":(0, 0, 0), "snap_align":False, "snap_normal":(0, 0, 0), "gpencil_strokes":False, "cursor_transform":False, "texture_space":False, "remove_on_cancel":False, "release_confirm":False, "use_accurate":False})
bpy.ops.mesh.extrude_region_move(MESH_OT_extrude_region={"use_normal_flip":False, "mirror":False}, TRANSFORM_OT_translate={"value":(0, 0, 1.69231), "orient_type":'NORMAL', "orient_matrix":((0, 0, -1), (1, 0, 0), (0, -1, 0)), "orient_matrix_type":'NORMAL', "constraint_axis":(False, False, True), "mirror":False, "proportional":'DISABLED', "proportional_edit_falloff":'SMOOTH', "proportional_size":1, "snap":False, "snap_target":'CLOSEST', "snap_point":(0, 0, 0), "snap_align":False, "snap_normal":(0, 0, 0), "gpencil_strokes":False, "cursor_transform":False, "texture_space":False, "remove_on_cancel":False, "release_confirm":False, "use_accurate":False})
bpy.ops.machin3.edit_mode()
bpy.context.space_data.system_bookmarks_active = 2
RuntimeError: Error: 'measureit_main_panel' doesn't contain 'PT' with prefix & suffix
NameError: name 'unregister_class' is not defined
RuntimeError: Error: 'view3d.manipulator_of' doesn't contain 'MT' with prefix & suffix
Hope that helps
Regards
Eric
Hi Brecht
Just downloaded the latest 2.8 build for MacOS (Hash a58a4f48bef4) and the problem seems to have been "fixed". All my addons are working fine with no error reports. I have had this problem early on where an addon would stop working for a new daily release then work again for the next. This is the longest period (three releases) where addons stopped working and started again. It may be something to do with the MacOs Build process?
Anyway, if it happens again I will make another report and try and give as much information as possible.
Added subscriber: @BrendonMurphy
hi, yes there was a big change in nightly builds recently. they have been reverted to give addons devs some time to fix the issues. Yopu should still maybe get some warnings in the console. this may serve to help addons devs update.
closing as resolved
