Del #63163
Reference: blender/blender#63163
Del
Added subscriber: @troy_s
Added subscriber: @brecht
Please use the bug submission template and follow the reporting guidelines:
https://developer.blender.org/maniphest/task/edit/form/1/
Particularly, mention the exact Blender version and provide exact steps to reproduce the problem.
This comment was removed by @troy_s
Added subscriber: @intracube
Screenshot was from me.
extra details:
Operating system: SUSE Leap 15.0
Graphics card: NVidia GTX 560ti (official drivers)
Broken: 2.80,
a4869df4c9
, x86_64 linux, 2019-03-31 (buildbot)Worked: -
Using OCIO configurations and LUTS besides the ones officially bundled (eg filmic_blender) causes the rendered 3d viewport values to skew - especially visible towards display referred peak values. Mid ranges seem unaffected.
note: This is only a realtime rendered 3d viewport issue. Applies to Cycles/Eevee. Final renders are unaffected.
I can repro the issue in
ociodisplay
v1.1.0, but not in master. So it seems to be a bug in OpenColorIO that we can fix by upgrading.v1.1.0 is the latest official release and master is v2 in development, with API breaking changes and potential instability. So upgrading is not entirely trivial. Some info here:
https://github.com/imageworks/OpenColorIO/blob/master/docs/tsc/meetings/2019-03-04.md
Real-time Viewer Broken GPU Transformsto Inaccurate GPU color management for custom OCIO configInaccurate GPU color management for custom OCIO configto Inaccurate GPU color managementInaccurate GPU color managementto Inaccurate GPU color management for custom OCIO configAs far as I know this does not happen with the builtin config, so please leave the more descriptive title.
So a case where a user has specified a custom config rather than the Blender builtin one.
The config.ocio and its default sRGB transform as bundled with Blender work fine as far as I can tell. Perhaps because it has a larger output range than 0..1 which somehow sidesteps the problem.
Editing the builtin config to use a different sRGB transform could of course show the bug, but then it's a different config.
Since the same bug happens in
ociodisplay
with your filmic config, it seems the bug is in OpenColorIO and not Blender. I don't see any indication of the Blender GPU code being broken. There may be a way to work around the bug in your filmic config, so that it also works in other apps integrating OpenColorIO that presumably have the same problem if they support GPU acceleration.We're not likely to spend time fixing a bug in OpenColorIO v1 if v2 is coming out soon enough.
Well, I have clear evidence of the bug being in OpenColorIO since it's also broken in
ociodisplay
. You only seem to be speculating that it must work because it's a basic transform. So the conclusion to me is clear, which is that it's not a bug in the Blender code unless someone proves otherwise.Yep, I modified the bundled srgb.spi1d to match the same range as the one provided by blender_filmic and the same issue then appears. So as you say, possibly the extension at the top end of the LUT hides the issue.
I can't reproduce the bug with ociodisplay set to
Image ColorSpace->sRGB OETF + Transform->sRGB OETF
- but, if ociodisplay is left with the default ('Linear') Image ColorSpace, then OCIO v1.1.0 does have reduced highlights, which look suspiciously similar to the issue in Blender, although not exactly the same values (240, 1, 1).OCIO master (2019-04-04) hits peak display values and looks correct:
But if this is related, why is Blender using the Linear path for display instead of sRGB/sRGB?
Source test image:
Rendering works in Linear color space, that's what we need to convert from.
Just tried v1.1.1 as it was released yesterday. Unfortunately the same behaviour as 1.1.0.
Huh, @intracube posted a screenshot confirming it doesn't work in ociodisplay?
If sRGB -> sRGB works that's irrelevant, that's not the transform needed and it's a no-op.
If you select the same color space for Image ColorSpace and Transform in ociodisplay, like
, that's a no-op.Please stop wasting my time and make an effort to understand what is going on here, instead of claiming I'm wrong without any logical explanation.
Inaccurate GPU color management for custom OCIO configto DelChanged status from 'Open' to: 'Archived'
Added subscriber: @Acrivec
Wow, a rage quit in bugtracker.
