Grease Pencil Strokes visible behind solid objects #63191
Reference: blender/blender#63191
Operating system: Darwin-18.5.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 560X OpenGL Engine ATI Technologies Inc. 4.1 ATI-2.8.38
Broken: version: 2.80 (sub 53), branch: master, commit date: 2019-04-01 14:09, hash:
9ddf0c9d38
Grease Pencil Strokes visible behind solid objects. That is, within a single Grease Pencil object and you have strokes in front of and behind a solid object, you can see the strokes behind the object through the strokes in front of the object even though the object is completely opaque. This is problematic because I am trying to animate some linework on all sides of a surface of a 3D object.
I am attaching a .blend file here that illustrates the problem. Later I'll describe how I created this file.
TransparentGreasePenci.blend
To observe the problem:
Observe that through the red strokes in front of the sphere you can see artifacts of the red strokes that should be hidden behind the sphere.
I don't know if this behavior is expected or not. While it could be a cool effect, it completely defeats the workflow I was trying to achieve or it will force me to split my Grease Pencil strokes among multiple GP objects. If I had to guess, it looks like the GP objects are rendered to a separate buffer and merged, which means they only get a single Z value to compare with other 3D geometry. Of course, I haven't looked at the code yet.
How I created the example:
Added subscriber: @ChuckOcheret
Added subscriber: @antoniov
What mode do you have here?
Set to 3D Location. When you set to default mode (2D Layers) the strokes are visible if you put a mesh in front.
Your file in 3D Location mode.
Note: Anyway, we still have a problem with alpha strokes and we are working to fix it.
I've tried both 3D location (my current setting) as well as 2D layers with much the same effect. Even in the example you posted above, you can see the rear strokes through the sphere, but only where there are strokes in front of the sphere. The effect when animating is that the strokes in front serve as a transparency map for the sphere. Except all you can see through the sphere are the strokes from the same GP object behind it.
Yes, I know for alpha strokes...it's a already detected problem. Wwe are looking for a solution.
I just tried it with completely opaque strokes drawn with strength set to 1.0 and no pressure sensitivity. This is just to ensure that there is absolutely no transparency involved. If you look from the front (Numpad 1) you can see the that it looks like the far strokes are subtracting from the near strokes. When you look from the back (Ctrl-Numpad 1) it all looks ok.
But, if I reduce the material's stroke Alpha to, say, .5, then you still get the subtractive effect in front view but you get the transparency effect from the rear view.
I'm supplying a new .blend file that shows this. You can play with the material's stroke alpha to see the different effects.
TransparentGreasePenci1.blend
Closed as duplicate of #59425
