Blender crashing while rendering scene with linked rigs #63603
6 Participants
Reference: blender/blender#63603
Win 10 Pro
32GB RAM
3 SSDs
2x Xeon 2690 v2 (20cores @3GHz)
RTX 2080 ti
Broken: (blender-2.80-009dbc2bc9fb)
Worked: (2.79.7)
I'm working on an animation with a linked scene and two linked rigs. It will run/render fine in 2.79.7 but in 2.8 when I render image about 30 seconds will pass while syncing then blender crashes(disappears). My memory appears to be well in acceptable range when this happens. I ran debug log while this happened I attached the two log files the crash produced.
Last line was in log was: Error : EXCEPTION_ACCESS_VIOLATION
Doesn't matter if I render CPU only, GPU only or both (I'm using supported feature set)
I have this same file in production in 2.79.7 with no issues I figured I'll try 2.8 to see if I could improve render time in cycles.
blender_debug_output - Copy.txt
blender_system_info - Copy.txt
Added subscriber: @Tet
Added subscriber: @rjg
Can you share a minimal .blend file where this error occurs?
Looks like this might be the same issue as #63582
Unfortunately this is a full blown production file and I'm not sure how to reproduce the issue simply. I was hoping the logs could shine some light on it. If I can find a way to reproduce it simply I will post it.
Not sure this is the same issue. Specifically, my issue hangs/freezes upon "synchronizing linked objects" after clicking render image via cycles. The render time freezes at 4 seconds then crashes 30 seconds later before any pixels are rendered.
Added subscriber: @AnsettAnimation
Added subscriber: @lichtwerk
Got some dependency cycles reported here:
Added subscriber: @brecht
We can't investigate this without a .blend file, the backtraces do not provide enough information.
I was able to reproduce the problem with a simple .blend file, it has to do with the subsurf being set higher than I needed (render=5) for an object in my scene. If I reduce the "render subsurf" it will render fine in 2.8. However keeping the render subsurf set to 5, it will render fine in 2.79.7 but crashes for me in 2.8 as described in my original post.2019-04-18-RenderBug_2_8_c.blend
Added subscriber: @ZedDB
Does this still happen for you with the latest blender beta? I don't seem to get any crashes when rendering with a subsurf level of 5.
gah, wrong ticket.
I can confirm this does render with the latest version. Thanks!
