CTRL for InvertSnapping (feels like) Is HardCoded Somewhere #63641
Reference: blender/blender#63641
Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 417.35
Broken: version: 2.80.0-git.860a9f979d60-windows64
Worked: I don't think I had this working (like 2.7x) ever
This is going to be hard to assure you guys that this is really a thing.
Basically SNAPPING (to be precise Invert Snapping) is hardcoded somewhere with CTRL.
I use a customized blender version, where I have CTRL+TWEAK LMB set for "Move" (transform.translate).
The behavior I get is: as soon as I enter "Move Mode" my snapping is INVERTED (this is totally undesired).
I went and Disabled/Unchecked all of the SNAPPING entries from the KEYMAP, and as expected all snapping is off now. But I still get the same thing when I invoke "Move Mode" with CTRL+TWEAK LMB, the snapping gets inverted!
Checked with FactoryDefault and I get the same thing.
What I will do is give you 2 setups you can test this with pretty fast.
Install the 1st BlenderPrefs and with the Default Cube selected, press CTRL + TWEAK + LMB. You will see that Snapping will get Enabled, even though it was Disabled prior to that. You can then toggle it by Releasing CTRL (but this is a major inconvenience to get around the initial bug). And by pressing CTRL again you can toggle it again, You are in MoveMode this whole time!
Now install the 2nd BlenderPrefs. And again with the Default Cube selected, press CTRL + TWEAK + LMB. As before, you will see that Snapping will get Enabled, even though it was Disabled prior to that. But this time you won't be able to toggle it, because all CTRL hotkeys for SNAPPING have been unchecked in the Keymap. This is to show that the initial SnappingToggle that happend is not in the Keymap entries (at least I can't find it). And while were at it, maybe the reason I can not find it is that the Modals don't show in keymap Search filters! Maybe that's something that could be addressed as well?
This is where you can grab the 2 BlendPrefs settings to test this out:
http://edge-loop.com/images/blender/bugtracker/Blender_280_CTRL_Snapping_Bug_TestingPreferences.zip
That is basically just the 2.80 folder from "C:\Users...........\AppData\Roaming\Blender Foundation\Blender" that you need to place there in order to test the bug.
Thanks again to anyone looking into this!
Added subscriber: @0rAngE
This issue was referenced by
0ca9ce21ab
Added subscribers: @WilliamReynish, @ZedDB
Right, seems to be hard coded in
blender/editors/transform/transform.c:2412
.@WilliamReynish I'm unsure if we can easily move this out to the keymap. Any input etc?
Added subscriber: @brecht
Changed status from 'Resolved' to: 'Open'
I didn't actually test this, just noticed the bug in not ignoring disabled keymap items and fixed that. There may be another issue here, can someone test?
Brecht,
I'm kind of deep into this, that's why I was able to catch this. Once I get the buildbot with the fix, I'll run it through tests with my setup. I can report back here, if it's OK with you.
Thanks again guys for looking into this!!! This was a major roadblock with a custom setup that is similar to something I use.
Appreciate it!!!
Tested with
5d8030b8f3
works well now!Thanks Brecht, much appreciated!!
