looptools gstretch/gpencil bug #63682
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
9 Participants
Reference: blender/blender-addons#63682
Operating system: windows 7 64 bits
Graphics card: gforce 9800gt
Broken:
It does not work well and if you press Gstrech it shows a bug
just press GStrech and they will see the error
Added subscriber: @ArielEduardoGimenez
#63811 was marked as duplicate of this issue
Added subscriber: @StephenSwaney
From the barely legible error, it looks like there is no Grease Pencil stroke associated with this object.
Got a .blend for us that shows the problem?
yes, try this .blend although the problem also appears with a new .blend file
I use google translate{F6954713}
.blend
compressed in zip{F6954776}
Also if you open a new file and press gstrech you will see what the bug does.
The tool is malfunctioning in general.
google translate
Added subscriber: @Gvgeo-1
From what I can tell, grease_pencil was in object or scene in 2.79.
The addon used the objects grease_pencil to stretch the vertices.
Now grease_pencil is a separate object.
The error is exactly that, object has no grease_pencil anymore.
Not sure how the annotation work. Must be in scene?
The addon needs to be updated for 2.80.
The default cube is enough for the error.
I really do not know what is wrong, but thanks for the explanation .. And yes, with a cube you can see the error
Added subscribers: @makadir, @lichtwerk
looptools BUG!to looptools gstretch bugWill confirm for now, not sure yet how to convert this feature to 2.8, needs some thinking [since gpencil is indeed a separate object in 2.8]
looptools gstretch bugto looptools gstretch/gpencil bugin general, it was working with 2.80.54 (abt 6th april build), some thing changed by this time.
Added subscriber: @BrendonMurphy
hi, I've been looking here: https://docs.blender.org/api/blender2.8/bpy.ops.gpencil.html
This led to an error here:
which led to errors in:
this was to do with
@lichtwerk I'm just guessing and stuck on frame atm. maybe on the right track?
Added subscriber: @yursiv
This comment was removed by @yursiv
Added subscribers: @antoniov, @cwolf3d
Committed
934b32af8e
although it only part fixes the issue.Using the default cube I needed to subdivide an edge at least once for it to run in Spread modes.
Project function not working.
@cwolf3d and @antoniov are helping with the issue.
LoopTools: Gstretch fix. Grease pencil must have name 'GPencil'. Script take only the first strokes.
https://developer.blender.org/rBAb23f15603088f2e382ce9a53093b58debc3d70e6
closing as resolved
