Material tab crash with Intel HD 4x00 on Windows 7/8
Operating system: Windows 8.1
Graphics card: Intel(R) HD GraphicsFamily (driver up to date), Visual C++ 2013 Redistributable Package installed
Broken: (2.8, downloaded April 26 from https://www.blender.org/2-8/, 513b71c89ad0
Worked: 2.79, stable version and former versions
I doubleclick blender.exe, it opens okay and when I go to the material tab of the initial cube of the default startup - Blender disappears
How can I run --debug-gpu in the terminal if this could be the solution as mentioned in
T55787 ?
Sebastian Parborg (zeddb) triaged this task as Needs Information from User priority.
This sounds like an issue that was solved recently. Could you try the latest build and see if it is solved for you?
I downloaded blender-2.80-a372e5e426e4-win64 today and Blender still crashes when I click on the material tab of the initial cube of the default startup. The address is different now.
You can run it with the debug gpu flags by running the blender_debug_gpu.cmd file.
Here are the log files.
DEBUG_OUTPUT.TXT:
witching to fully guarded memory allocator.
Blender 2.80 (sub 60)
Build: 01/05/2019 17:11 Windows Release
argv[0] = blender
argv[1] = --debug
argv[2] = --debug-gpu
argv[3] = --python-expr
argv[4] = import bpy; bpy.ops.wm.sysinfo(filepath=r'C:\Users\ich\AppData\Local\Temp\blender\debug_logs\blender_system_info.txt')
read file C:\Users\ich\AppData\Roaming\Blender Foundation\Blender\2.80\config\userpref.blend
Version 280 sub 59 date 2019-04-26 06:00 hash 513b71c89ad0
Read prefs: C:\Users\ich\AppData\Roaming\Blender Foundation\Blender\2.80\config\userpref.blend
read file
Version 280 sub 39 date unknown hash unknown
GPUTexture: create : TEXTURE_CUBE_MAP, RGBA16F, w : 2, h : 2, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_1D, RGBA8, w : 1, h : 0, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1, h : 1, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_3D, RGBA8, w : 1, h : 1, d : 1, comp : 4, size : 0.00 MiB
Using KHR_debug extension
GL application marker: Successfully hooked OpenGL debug callback.
found bundled python: C:\Users\ich\Downloads\Blender28_0205\blender-2.80-a372e5e426e4-win64\blender-2.80.0-git.a372e5e426e4-windows64\2.80\python
GPUTexture: create : TEXTURE_2D, RGBA8, w : 961, h : 26, d : 0, comp : 4, size : 0.10 MiB
GPUTexture: create : TEXTURE_2D, R8, w : 16384, h : 128, d : 0, comp : 1, size : 2.00 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 405, h : 26, d : 0, comp : 4, size : 0.04 MiB
GL API performance: Vertex shader recompiled due to state change.
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1366, h : 20, d : 0, comp : 4, size : 0.10 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 237, h : 26, d : 0, comp : 4, size : 0.02 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 29, h : 419, d : 0, comp : 4, size : 0.05 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 208, h : 419, d : 0, comp : 4, size : 0.33 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 237, h : 185, d : 0, comp : 4, size : 0.17 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1128, h : 26, d : 0, comp : 4, size : 0.11 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1128, h : 24, d : 0, comp : 4, size : 0.10 MiB
GL API deprecated behavior: Wide lines have been deprecated. glLineWidth set to 2.000000. glLineWidth with width greater than 1.0 will generate GL_INVALID_VALUE error in future versions
GPUTexture: create : TEXTURE_2D, RGBA8, w : 56, h : 580, d : 0, comp : 4, size : 0.12 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1128, h : 606, d : 0, comp : 4, size : 2.61 MiB
GPUTexture: create : TEXTURE_2D, DEPTH24_STENCIL8, w : 1128, h : 606, d : 0, comp : 1, size : 2.61 MiB
GPUTexture: create : TEXTURE_1D, RGBA8, w : 257, h : 0, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_1D, RGBA8, w : 256, h : 0, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, R11F_G11F_B10F, w : 1128, h : 606, d : 0, comp : 3, size : 2.61 MiB
GPUTexture: create : TEXTURE_2D, R32UI, w : 1128, h : 606, d : 0, comp : 1, size : 2.61 MiB
GPUTexture: create : TEXTURE_2D, RG16, w : 1128, h : 606, d : 0, comp : 2, size : 2.61 MiB
GPUTexture: create : TEXTURE_2D, RGBA16F, w : 64, h : 64, d : 0, comp : 4, size : 0.06 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 16, h : 16, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, DEPTH_COMPONENT24, w : 1128, h : 606, d : 0, comp : 1, size : 1.96 MiB
GPUTexture: create : TEXTURE_2D, R16UI, w : 1128, h : 606, d : 0, comp : 1, size : 1.30 MiB
GPUTexture: create : TEXTURE_2D, R8, w : 16384, h : 64, d : 0, comp : 1, size : 1.00 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 527, h : 491, d : 0, comp : 4, size : 0.99 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 443, h : 91, d : 0, comp : 4, size : 0.15 MiB
read file
read file
Version 280 sub 57 date unknown hash unknown
read file
Version 280 sub 20 date 2018-07-14 11:44 hash 27ba739fb79
GPUTexture: create : TEXTURE_2D, DEPTH24_STENCIL8, w : 32, h : 32, d : 0, comp : 1, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, RGBA32F, w : 32, h : 32, d : 0, comp : 4, size : 0.03 MiB
GPUTexture: create : TEXTURE_2D, RGBA16F, w : 32, h : 32, d : 0, comp : 4, size : 0.02 MiB
GPUTexture: create : TEXTURE_2D, R11F_G11F_B10F, w : 32, h : 32, d : 0, comp : 3, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, RG16I, w : 16, h : 16, d : 0, comp : 2, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, R16F, w : 16, h : 16, d : 0, comp : 1, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, R32F, w : 16, h : 16, d : 0, comp : 1, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, RG16, w : 32, h : 32, d : 0, comp : 2, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D_ARRAY, RGBA16F, w : 64, h : 64, d : 20, comp : 4, size : 1.25 MiB
GPUTexture: create : TEXTURE_1D, RG16F, w : 1024, h : 0, d : 0, comp : 2, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D_ARRAY, RGBA8, w : 32, h : 32, d : 129, comp : 4, size : 0.50 MiB
GPUTexture: create : TEXTURE_2D_ARRAY, R11F_G11F_B10F, w : 628, h : 628, d : 2, comp : 3, size : 3.01 MiB
GPUTexture: create : TEXTURE_2D_ARRAY, RGBA8, w : 1, h : 1, d : 1, comp : 4, size : 0.00 MiB
GPUShaderInterface: Warning: Uniform 'attr' not found!
GPUShaderInterface: Warning: Uniform 'hairPointBuffer' not found!
GPUShaderInterface: Warning: Uniform 'hairUVBuffer' not found!
GPUShaderInterface: Warning: Uniform 'hairColBuffer' not found!
GPUShaderInterface: Warning: Uniform 'colorBuffer' not found!
GPUShaderInterface: Warning: Uniform 'depthBuffer' not found!
GPUShaderInterface: Warning: Uniform 'minzBuffer' not found!
GPUShaderInterface: Warning: Uniform 'planarDepth' not found!
GPUShaderInterface: Warning: Uniform 'texHammersley' not found!
GPUShaderInterface: Warning: Uniform 'texJitter' not found!
GPUShaderInterface: Warning: Uniform 'sssTexProfile' not found!
GPUShaderInterface: Warning: Uniform 'inScattering' not found!
GPUShaderInterface: Warning: Uniform 'inTransmittance' not found!
GPUTexture: create : TEXTURE_CUBE_MAP, DEPTH_COMPONENT24, w : 512, h : 512, d : 0, comp : 1, size : 4.50 MiB
GPUTexture: create : TEXTURE_CUBE_MAP, RG32F, w : 512, h : 512, d : 0, comp : 2, size : 24.00 MiB
GPUTexture: create : TEXTURE_2D_ARRAY, RG32F, w : 1255, h : 1255, d : 2, comp : 2, size : 48.07 MiB
GPUTexture: create : TEXTURE_2D_ARRAY, DEPTH_COMPONENT24, w : 1024, h : 1024, d : 4, comp : 1, size : 12.00 MiB
GPUTexture: create : TEXTURE_2D_ARRAY, RG32F, w : 1024, h : 1024, d : 4, comp : 2, size : 64.00 MiB
GPUTexture: create : TEXTURE_2D_ARRAY, RG32F, w : 1024, h : 1024, d : 1, comp : 2, size : 16.00 MiB
Error : EXCEPTION_ACCESS_VIOLATION
Address : 0x00007FF78C256830
Module : C:\Users\ich\Downloads\Blender28_0205\blender-2.80-a372e5e426e4-win64\blender-2.80.0-git.a372e5e426e4-windows64\blender.exe
SYSTEM_INFO.TXT:
Blender 2.80 (sub 60) System Information
Blender:
version: 2.80 (sub 60), branch: blender2.7, commit date: 2019-05-01 16:58, hash: a372e5e426e4, type: Release
build date: 01/05/2019, 17:11
platform: Windows
binary path: 'C:\\Users\\ich\\Downloads\\Blender28_0205\\blender-2.80-a372e5e426e4-win64\\blender-2.80.0-git.a372e5e426e4-windows64\\blender.exe'
build cflags: /W3 /w34062 /w34115 /w34189 /wd4018 /wd4146 /wd4065 /wd4127 /wd4181 /wd4200 /wd4244 /wd4267 /wd4305 /wd4800 /wd4828 /wd4996 /we4013 /we4133 /we4431 /w35038 /DWIN32 /D_WINDOWS /W3 /nologo /J /Gd /MP -openmp
build cxxflags: /W3 /w34062 /w34115 /w34189 /wd4018 /wd4146 /wd4065 /wd4127 /wd4181 /wd4200 /wd4244 /wd4267 /wd4305 /wd4800 /wd4828 /wd4996 /we4013 /we4133 /we4431 /w35038 /DWIN32 /D_WINDOWS /W3 /GR /EHsc /nologo /J /Gd /MP /EHsc -openmp
build linkflags: /MACHINE:X64 /SUBSYSTEM:CONSOLE /STACK:2097152 /INCREMENTAL:NO /NODEFAULTLIB:msvcrt.lib /NODEFAULTLIB:msvcmrt.lib /NODEFAULTLIB:msvcurt.lib /NODEFAULTLIB:msvcrtd.lib /ignore:4049 /ignore:4217 /ignore:4221
build system: CMake
Python:
version: 3.7.0 (default, Aug 26 2018, 16:05:01) [MSC v.1900 64 bit (AMD64)]
paths:
'C:\\Users\\ich\\Downloads\\Blender28_0205\\blender-2.80-a372e5e426e4-win64\\blender-2.80.0-git.a372e5e426e4-windows64\\2.80\\scripts\\addons_contrib'
'C:\\Users\\ich\\Downloads\\Blender28_0205\\blender-2.80-a372e5e426e4-win64\\blender-2.80.0-git.a372e5e426e4-windows64\\2.80\\scripts\\addons'
'C:\\Users\\ich\\Downloads\\Blender28_0205\\blender-2.80-a372e5e426e4-win64\\blender-2.80.0-git.a372e5e426e4-windows64\\2.80\\scripts\\startup'
'C:\\Users\\ich\\Downloads\\Blender28_0205\\blender-2.80-a372e5e426e4-win64\\blender-2.80.0-git.a372e5e426e4-windows64\\2.80\\scripts\\modules'
'C:\\Users\\ich\\Downloads\\Blender28_0205\\blender-2.80-a372e5e426e4-win64\\blender-2.80.0-git.a372e5e426e4-windows64\\python37.zip'
'C:\\Users\\ich\\Downloads\\Blender28_0205\\blender-2.80-a372e5e426e4-win64\\blender-2.80.0-git.a372e5e426e4-windows64\\2.80\\python\\DLLs'
'C:\\Users\\ich\\Downloads\\Blender28_0205\\blender-2.80-a372e5e426e4-win64\\blender-2.80.0-git.a372e5e426e4-windows64\\2.80\\python\\lib'
'C:\\Users\\ich\\Downloads\\Blender28_0205\\blender-2.80-a372e5e426e4-win64\\blender-2.80.0-git.a372e5e426e4-windows64'
'C:\\Users\\ich\\Downloads\\Blender28_0205\\blender-2.80-a372e5e426e4-win64\\blender-2.80.0-git.a372e5e426e4-windows64\\2.80\\python'
'C:\\Users\\ich\\Downloads\\Blender28_0205\\blender-2.80-a372e5e426e4-win64\\blender-2.80.0-git.a372e5e426e4-windows64\\2.80\\python\\lib\\site-packages'
'C:\\Users\\ich\\Downloads\\Blender28_0205\\blender-2.80-a372e5e426e4-win64\\blender-2.80.0-git.a372e5e426e4-windows64\\2.80\\scripts\\freestyle\\modules'
'C:\\Users\\ich\\Downloads\\Blender28_0205\\blender-2.80-a372e5e426e4-win64\\blender-2.80.0-git.a372e5e426e4-windows64\\2.80\\scripts\\addons\\modules'
'C:\\Users\\ich\\AppData\\Roaming\\Blender Foundation\\Blender\\2.80\\scripts\\addons\\modules'
Python (External Binary):
binary path: 'C:\\Users\\ich\\Downloads\\Blender28_0205\\blender-2.80-a372e5e426e4-win64\\blender-2.80.0-git.a372e5e426e4-windows64\\2.80\\python\\bin\\python.EXE'
version: Python 3.7.0
Directories:
scripts:
'C:\\Users\\ich\\Downloads\\Blender28_0205\\blender-2.80-a372e5e426e4-win64\\blender-2.80.0-git.a372e5e426e4-windows64\\2.80\\scripts'
user scripts: 'C:\\Users\\ich\\AppData\\Roaming\\Blender Foundation\\Blender\\2.80\\scripts'
pref scripts: None
datafiles: 'C:\\Users\\ich\\AppData\\Roaming\\Blender Foundation\\Blender\\2.80\\datafiles\\'
config: 'C:\\Users\\ich\\AppData\\Roaming\\Blender Foundation\\Blender\\2.80\\config\\'
scripts : 'C:\\Users\\ich\\AppData\\Roaming\\Blender Foundation\\Blender\\2.80\\scripts\\'
autosave: 'C:\\Users\\ich\\AppData\\Roaming\\Blender Foundation\\Blender\\2.80\\autosave\\'
tempdir: 'C:\\Users\\ich\\AppData\\Local\\Temp\\blender_a03296\\'
FFmpeg:
avcodec: '58, 18, 100'
avdevice: '58, 3, 100'
avformat: '58, 12, 100'
avutil: '56, 14, 100'
swscale: ' 5, 1, 100'
SDL:
Version: 2.0.8
Loading method: linked (WITH_SDL_DYNLOAD=OFF)
Other Libraries:
OpenColorIO: 1, 1, 0
OpenImageIO: 1, 8, 13
OpenShadingLanguage: 1, 9, 9
OpenSubdiv: 0, 0, 0
OpenVDB: 5, 1, 0
Alembic: 1, 7, 8
OpenGL:
renderer: 'Intel(R) HD Graphics 4400'
vendor: 'Intel'
version: '4.2.0 - Build 10.18.10.3355'
extensions:
GL_3DFX_texture_compression_FXT1
GL_ARB_ES2_compatibility
GL_ARB_arrays_of_arrays
GL_ARB_base_instance
GL_ARB_blend_func_extended
GL_ARB_color_buffer_float
GL_ARB_compressed_texture_pixel_storage
GL_ARB_compute_shader
GL_ARB_conservative_depth
GL_ARB_copy_buffer
GL_ARB_debug_output
GL_ARB_depth_buffer_float
GL_ARB_depth_clamp
GL_ARB_depth_texture
GL_ARB_draw_buffers
GL_ARB_draw_buffers_blend
GL_ARB_draw_elements_base_vertex
GL_ARB_draw_indirect
GL_ARB_draw_instanced
GL_ARB_explicit_attrib_location
GL_ARB_fragment_coord_conventions
GL_ARB_fragment_program
GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader
GL_ARB_framebuffer_object
GL_ARB_framebuffer_sRGB
GL_ARB_geometry_shader4
GL_ARB_get_program_binary
GL_ARB_gpu_shader5
GL_ARB_gpu_shader_fp64
GL_ARB_half_float_pixel
GL_ARB_half_float_vertex
GL_ARB_instanced_arrays
GL_ARB_internalformat_query
GL_ARB_internalformat_query2
GL_ARB_map_buffer_alignment
GL_ARB_map_buffer_range
GL_ARB_multi_draw_indirect
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_occlusion_query
GL_ARB_occlusion_query2
GL_ARB_pixel_buffer_object
GL_ARB_point_parameters
GL_ARB_point_sprite
GL_ARB_program_interface_query
GL_ARB_provoking_vertex
GL_ARB_robustness
GL_ARB_sample_shading
GL_ARB_sampler_objects
GL_ARB_seamless_cube_map
GL_ARB_separate_shader_objects
GL_ARB_shader_atomic_counters
GL_ARB_shader_bit_encoding
GL_ARB_shader_image_load_store
GL_ARB_shader_objects
GL_ARB_shader_precision
GL_ARB_shader_storage_buffer_object
GL_ARB_shader_subroutine
GL_ARB_shading_language_100
GL_ARB_shading_language_420pack
GL_ARB_shading_language_packing
GL_ARB_shadow
GL_ARB_sync
GL_ARB_tessellation_shader
GL_ARB_texture_border_clamp
GL_ARB_texture_buffer_object_rgb32
GL_ARB_texture_buffer_range
GL_ARB_texture_compression
GL_ARB_texture_compression_bptc
GL_ARB_texture_compression_rgtc
GL_ARB_texture_cube_map
GL_ARB_texture_cube_map_array
GL_ARB_texture_env_add
GL_ARB_texture_env_combine
GL_ARB_texture_env_crossbar
GL_ARB_texture_env_dot3
GL_ARB_texture_float
GL_ARB_texture_gather
GL_ARB_texture_multisample
GL_ARB_texture_non_power_of_two
GL_ARB_texture_query_lod
GL_ARB_texture_rectangle
GL_ARB_texture_rg
GL_ARB_texture_rgb10_a2ui
GL_ARB_texture_storage
GL_ARB_texture_swizzle
GL_ARB_timer_query
GL_ARB_transform_feedback2
GL_ARB_transform_feedback3
GL_ARB_transform_feedback_instanced
GL_ARB_transpose_matrix
GL_ARB_uniform_buffer_object
GL_ARB_vertex_array_bgra
GL_ARB_vertex_array_object
GL_ARB_vertex_attrib_64bit
GL_ARB_vertex_buffer_object
GL_ARB_vertex_program
GL_ARB_vertex_shader
GL_ARB_vertex_type_2_10_10_10_rev
GL_ARB_viewport_array
GL_ARB_window_pos
GL_ATI_separate_stencil
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_blend_color
GL_EXT_blend_equation_separate
GL_EXT_blend_func_separate
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_clip_volume_hint
GL_EXT_compiled_vertex_array
GL_EXT_draw_buffers2
GL_EXT_draw_range_elements
GL_EXT_fog_coord
GL_EXT_framebuffer_blit
GL_EXT_framebuffer_multisample
GL_EXT_framebuffer_object
GL_EXT_geometry_shader4
GL_EXT_gpu_program_parameters
GL_EXT_gpu_shader4
GL_EXT_multi_draw_arrays
GL_EXT_packed_depth_stencil
GL_EXT_packed_float
GL_EXT_packed_pixels
GL_EXT_rescale_normal
GL_EXT_secondary_color
GL_EXT_separate_specular_color
GL_EXT_shadow_funcs
GL_EXT_stencil_two_side
GL_EXT_stencil_wrap
GL_EXT_texture3D
GL_EXT_texture_array
GL_EXT_texture_compression_s3tc
GL_EXT_texture_edge_clamp
GL_EXT_texture_env_add
GL_EXT_texture_env_combine
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_integer
GL_EXT_texture_lod_bias
GL_EXT_texture_rectangle
GL_EXT_texture_sRGB
GL_EXT_texture_sRGB_decode
GL_EXT_texture_shared_exponent
GL_EXT_texture_snorm
GL_EXT_texture_storage
GL_EXT_texture_swizzle
GL_EXT_transform_feedback
GL_IBM_texture_mirrored_repeat
GL_INTEL_fragment_shader_ordering
GL_INTEL_map_texture
GL_INTEL_performance_queries
GL_KHR_debug
GL_NV_blend_square
GL_NV_conditional_render
GL_NV_primitive_restart
GL_NV_texgen_reflection
GL_SGIS_generate_mipmap
GL_SGIS_texture_edge_clamp
GL_SGIS_texture_lod
GL_SUN_multi_draw_arrays
GL_WIN_swap_hint
WGL_ARB_buffer_region
WGL_ARB_create_context
WGL_ARB_create_context_profile
WGL_ARB_create_context_robustness
WGL_ARB_extensions_string
WGL_ARB_framebuffer_sRGB
WGL_ARB_make_current_read
WGL_ARB_multisample
WGL_ARB_pbuffer
WGL_ARB_pixel_format
WGL_ARB_pixel_format_float
WGL_EXT_create_context_es2_profile
WGL_EXT_create_context_es_profile
WGL_EXT_depth_float
WGL_EXT_extensions_string
WGL_EXT_pixel_format_packed_float
WGL_EXT_swap_control
WGL_EXT_swap_control_tear
WGL_NV_DX_interop
Implementation Dependent OpenGL Limits:
Maximum DrawElements Vertices: 1048576
Maximum DrawElements Indices: 1048576
GLSL:
Maximum Varying Floats: 64
Maximum Vertex Attributes: 16
Maximum Vertex Uniform Components: 4096
Maximum Fragment Uniform Components: 4096
Maximum Vertex Image Units: 16
Maximum Fragment Image Units: 16
Maximum Pipeline Image Units: 96
Cycles:
CPU device capabilities: SSE2 SSE3 SSE41 AVX AVX2
OpenCL device capabilities:
Number of platforms: 1
Platform #0
Platform Name: Intel(R) OpenCL
Platform Vendor: Intel(R) Corporation
Platform Version: OpenCL 1.2
Platform Profile: FULL_PROFILE
Platform Extensions: cl_intel_dx9_media_sharing cl_khr_byte_addressable_store cl_khr_d3d11_sharing cl_khr_dx9_media_sharing cl_khr_gl_sharing cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_icd cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics
Number of devices: 2
		Device: #0
			Device Name: Intel(R) HD Graphics 4400
			Device Vendor: Intel(R) Corporation
			Device OpenCL C Version: OpenCL C 1.2
			Device Profile: FULL_PROFILE
			Device Version: OpenCL 1.2
			Device Extensions: cl_intel_dx9_media_sharing cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_d3d10_sharing cl_khr_d3d11_sharing cl_khr_depth_images cl_khr_dx9_media_sharing cl_khr_gl_depth_images cl_khr_gl_event cl_khr_gl_msaa_sharing cl_khr_gl_sharing cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_icd cl_khr_image2d_from_buffer cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_intel_accelerator cl_intel_ctz cl_intel_motion_estimation
			Device Max clock frequency (MHz): 400
			Device Max compute units: 20
			Device Max work group size: 512
		Device: #1
			Device Name: Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz
			Device Version: OpenCL 1.2 (Build 76413)
			Device Extensions: cl_khr_fp64 cl_khr_icd cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_intel_printf cl_ext_device_fission cl_intel_exec_by_local_thread cl_khr_gl_sharing cl_intel_dx9_media_sharing cl_khr_dx9_media_sharing cl_khr_d3d11_sharing
			Device Max clock frequency (MHz): 1600
			Device Max compute units: 4
			Device Max work group size: 1024
Enabled add-ons:
io_scene_fbx (version: (4, 14, 5), path: C:\Users\ich\Downloads\Blender28_0205\blender-2.80-a372e5e426e4-win64\blender-2.80.0-git.a372e5e426e4-windows64\2.80\scripts\addons\io_scene_fbx\init__.py)
io_anim_bvh (version: (1, 0, 0), path: C:\Users\ich\Downloads\Blender28_0205\blender-2.80-a372e5e426e4-win64\blender-2.80.0-git.a372e5e426e4-windows64\2.80\scripts\addons\io_anim_bvh\
init.py)
io_mesh_ply (version: (1, 0, 0), path: C:\Users\ich\Downloads\Blender28_0205\blender-2.80-a372e5e426e4-win64\blender-2.80.0-git.a372e5e426e4-windows64\2.80\scripts\addons\io_mesh_ply\
init.py)
io_scene_obj (version: (3, 5, 6), path: C:\Users\ich\Downloads\Blender28_0205\blender-2.80-a372e5e426e4-win64\blender-2.80.0-git.a372e5e426e4-windows64\2.80\scripts\addons\io_scene_obj\
init.py)
io_scene_x3d (version: (2, 2, 1), path: C:\Users\ich\Downloads\Blender28_0205\blender-2.80-a372e5e426e4-win64\blender-2.80.0-git.a372e5e426e4-windows64\2.80\scripts\addons\io_scene_x3d\
init.py)
io_mesh_stl (version: (1, 1, 3), path: C:\Users\ich\Downloads\Blender28_0205\blender-2.80-a372e5e426e4-win64\blender-2.80.0-git.a372e5e426e4-windows64\2.80\scripts\addons\io_mesh_stl\
init.py)
io_mesh_uv_layout (version: (1, 1, 1), path: C:\Users\ich\Downloads\Blender28_0205\blender-2.80-a372e5e426e4-win64\blender-2.80.0-git.a372e5e426e4-windows64\2.80\scripts\addons\io_mesh_uv_layout\
init.py)
io_curve_svg (version: UNKNOWN, path: C:\Users\ich\Downloads\Blender28_0205\blender-2.80-a372e5e426e4-win64\blender-2.80.0-git.a372e5e426e4-windows64\2.80\scripts\addons\io_curve_svg\
init.py)
cycles (version: UNKNOWN, path: C:\Users\ich\Downloads\Blender28_0205\blender-2.80-a372e5e426e4-win64\blender-2.80.0-git.a372e5e426e4-windows64\2.80\scripts\addons\cycles\
init.py)
io_scene_gltf2 (version: (0, 9, 4), path: C:\Users\ich\Downloads\Blender28_0205\blender-2.80-a372e5e426e4-win64\blender-2.80.0-git.a372e5e426e4-windows64\2.80\scripts\addons\io_scene_gltf2\
init__.py)
attach the files by dragging them into the text area, don't paste a wall of text please.
Have you tried installing the latest graphics drivers from the Intel website? I don't think 10.18.10.3355 is the latest version.
https://downloadcenter.intel.com/
I updated the graphics driver from https://downloadcenter.intel.com/ and 2.8 still crashes the same way.
Sebastian Parborg (zeddb) raised the priority of this task from Needs Information from User to Waiting for Developer to Reproduce.May 6 2019, 2:14 PM
Some update from my side:
I downloaded 2.8 yesterday (May 19th)and did some tests.
  1. Starting from Sculpting menu I can click the materials button without crashing. The crash happens when I try to change something in the right-hand menu.
  2. Starting from General Menu the crash still happens when I click on the materials button
Another crash scenario is shown in the figure below. In sculpting menu I can render when I set the render engine to cycles, I can render 50% of the time when I set render engine to workbench and I never can render with Eevee.
Brecht Van Lommel (brecht) renamed this task from 2.8 crashes when material tab is clicked to Material tab crash with Intel HD 4x00 on Windows 7/8.May 21 2019, 8:48 AM
Brecht Van Lommel (brecht) lowered the priority of this task from Waiting for Developer to Reproduce to Confirmed, High.
Marking as high priority since there are many reports about this, even though we haven't reproduced it ourselves yet.
From the bug reports, at least these Intel drivers versions are problematic. They are old drivers from 2014.
10.18.10.3355
10.18.10.3412
And indeed I can reproduce a crash (and other display issues) with my own Intel HD 4600 and 10.18.10.3412 drivers.
However recent drivers from the Intel website work fine for me:
10.18.14.5057 (15.36.35)
So my questions for users with this crash are:
  • Is there a specific reason you are still using old drivers?
  • Can you try downloading drivers from the Intel website and installing them?
  • If it fails or refuses to install, can you show a screenshots of the error it gives?
  • If installing worked and it still crashes, can you attach the system_info.txt?
I cannot install the driver 10.18.14.5057 (15.36.35) since the installer says "This operating system is not supported." The Intel page says the Acer TMP255-M has a proprietary graphics driver and Acer says it is an Intel driver. I contacted Acer support.
Acer recommends to buy a new computer. Original text:
I thought having windows updated my do us justice, unfortunately at this point. I'd advice you to get a machine that can handle the graphic of the animation application.
What a tech support...
Have you tried switching to cycles and see if it does the same thing?
  • I can switch to cycles and render the cube
  • When I switch back to Eevee and click render it crashes again
  • When I switch back to Eevee and click on a property within the materials tab it crashes also
So from what I can tell, the cause of the problems here is old drivers on Windows 7/8 that the laptop manufacturer prevents to be upgraded.
We can't officially support such old drivers, we don't have the resources to debug and work around these issues. Upgrading to Windows 10 may work around the problem, other than that I don't think we can do much here.
