SHIFT D to Duplicate is activating proportional editing and moving the primary object from its initial place
Operating system: Windows-10-10.0.14393 64 Bits
Graphics card: Intel(R) HD Graphics 4400 Intel 4.3.0 - Build 20.19.15.5063
Broken: version: 2.80 (sub 60), branch: master (modified), commit date: 2019-04-30 07:24, hash: rB546e20f5a2c0
Shift D is duplicating objects with Proportional editing activated by default.
For 3d objects shift D is duplicating the object but moving the primary object along with the duplicate.
In case of grease pencil, unable to duplicate key frames using Shift D it is only working as move key frame
Open blender with general template
select the cube
press shift d to duplicate and move the mouse
object is duplicated but the location of primary object is also shifted to last confirmed location of duplicate object.
In case of grease pencil key frames select any keyframe and press shift D it only moves the key frame. I think key frame is getting duplicated but as both the keyframes are in one time frame the end result shows only 1 keyframe.
Philipp Oeser (lichtwerk) triaged this task as Confirmed, Medium priority.
Confirmed, @Campbell Barton (campbellbarton) : mind checking?
Philipp Oeser (lichtwerk) raised the priority of this task from Confirmed, Medium to Confirmed, High.Apr 30 2019, 12:35 PM
