Blender 2.79 to 2.80 material edit breaks material #64069
2 Participants
Reference: blender/blender#64069
Operating system: Ubuntu 16.04
Graphics card: MSI 1080Ti
Broken: 2.80,
75f551faca
, master, 2019-04-07Worked: 2.79
The modifications to the material shader nodemap break the texture.
When the nodes are saved in 2.79, and opened in 2.80, before displacement outputs, we prepend a displacement node. This causes our texture to go all black or all white.
Download
MAT_test.blend
, created on blender 2.79. Look at the custom bump map being used in the material called:Changed
. Save this file.Open the file in
Blender 2.80
and look at the material inRendered
orLookDev
.The material has changed from its original color (teal) to black.
Note: This modification to the material node-tree does not occur if the Cube object in
MAT_test.blend
is appended to a new file inBlender 2.80
.Note:
MAT_test.blend
is saved in2.79
,MAT_test_new.blend
is saved in2.80
, and is the expected outcome of the above steps.MAT_test.blend
MAT_test_new.blend
Added subscriber: @zakleap
Added subscriber: @ZedDB
I can not reproduce this on my end. The 2.79 file is teal in rendered mode in both 2.79 and the latest 2.8 build for me.
@ZedDB I can confirm that in the latest version, the issue remains --> hash
480a09a92f7f
.You may have been looking at the rendered version through cycles.
Eevee
rendered view orLookDev
show an all black cube.The teal color comes back if the added
Displacement
node is bypassed.I am happy to supply any more information.
Eevee/Lookdev does not support displacement/vector displacement.
@ZedDB In that case, should the displacement node be automatically added during conversion? If it's not supported, wouldn't it be better to add the displacement node only to the cycles material output and not to the eevee?
There are no separate materials anymore in 2.8. Eevee and cycles both uses the same.
@ZedDB
Material Output
still supports rendering engine specific outputs.If the displacement node is not supported for
Eevee
, the automated modifier should instead create twoMaterial Output
nodes, one forCycles
and one forEevee
and connect the displacement node to theCycles - Material Output
node and not to theEevee - Material Output
node. It doesn't make sense to introduce unsupported nodes to the Eevee shader if we don't need to.There is no eevee backend in 2.79 and your file is using cycles. So if you want anything else to happen, then this is a feature request and should go to: https://blender.community/c/rightclickselect/
