Selection inconsistencies when switching collections #64312
5 Participants
Reference: blender/blender#64312
Operating system: Arch Linux
Graphics card: GTX 970
Broken: 2.80,
036e95bb21
I know layers and collection aren't fully compatible, but with the new collection system it seems impossible to make a selection of objects that is maintained when switching collections with the 1,2..0 keys. The changes in selection state also seem inconsistent.
See the attached scene containing 3 collections and 4 objects. The plane is in all 3 collections, the other objects only in one of the collections each.
All in all it would be useful if the object selection is not touched in any way when switching collections, like it was with layers. Collections and the current selection (to me) appear to be orthogonal concepts. And in order to organize collections visually (i.e. without involving the outliner) you want to be able to switch between collections while maintaining the current selection to determine which objects to move between collections.
By the way, https://developer.blender.org/T55162 mentions the dash (-) key as being usable to switch collections, but that does not seem to work?
collections.blend
Added subscriber: @PaulMelis
Added subscriber: @ZedDB
This seems to be a feature request and show go to: https://blender.community/c/rightclickselect/
Part of this may be a feature request, but can you explain the logic between what stays selected when switching collections? Because it seems inconsistent/unpredictable and therefore buggy.
This is a legit bug, I will look at it.
Added subscribers: @Sergey, @dfelinto
Basically layer_collection_sync calls BKE_base_eval_flags right away while iterating over the bases.
However when a parent/sibling collection is to influence the collection flag of an object that exists in more than one collection, it is too late since we deselect the object in BKE_base_eval_flags right away.
A fix would be to move the BKE_base_eval_flags call outside layer_collection_sync. However I think we need some of these settings set as early as possible.
In this case I think the best is to have a separate BKE_base_eval_flags_select_update to deselect the base if it is not selectable, and we run it separately.
@Sergey thoughts?
This issue was referenced by
bfa6cb3a7d
As from dependency graph point of view you should be able to simply remove
BKE_base_eval_flags()
fromlayer_collection_sync
.Dependency graph will update base flags via
BKE_object_eval_eval_base_flags()
.BKE_layer_collection_sync
must leave every base'sflag_from_collection
in a correct state. Those are the bits which are dependent on the settings from collections.Any modifications to the collections which affect base flags must tag scene for
ID_RECALC_BASE_FLAGS
.BKE_object_eval_eval_base_flags
must be able to evaluate correct base flagsThis function is called after
is calculated.Any change to object/base which affects on base flags must tag object for
.I don't see a reason why would you treat selection flags differently. From my point of view this doesn't make sense. But this isn't my area actually.
It is indeed strange that we call BKE_base_eval_flags instead of BKE_object_eval_eval_base_flags. That said calling
DEG_id_tag_update((ID *)&scene->id, ID_RECALC_BASE_FLAGS);
is not enough so I would say the patch should be good as it is.Changed status from 'Open' to: 'Resolved'
