glitchy pixels over objects in viewport for look-dev mode #64454
Reference: blender/blender#64454
Operating system: Windows 10
Graphics card: n/a; HP Pavillion laptop w/ intel CORE i5 7th gen processor. Render settings use CPU to render
Broken: (example: 2.80,
edbf15d3c0
, master, 2018-11-28, as found on the splash screen)Worked: (optional)
This problem is happening with this file for this and the previous Blender 2.80 Beta release. Multiple moderators on Stack Exchange directed me to report this as a bug. When in look-dev mode, objects appear with multicolored pixels glitching over the object. This was not the case when I first started building the scene. This happened at some point after re-saving under a different file name and deleting all instances of original objects (for .fbx export purposes).
Try making objects with Principled BDSF shaders on them, instance them a few times, delete the instances, and export the the originals as .fbx (or maybe delete the originals and try exporting instances?). Try re-saving the file too. It does not matter if you are in Cycles or Eevee.
BoosterTower05.blend opens without errors.
BoosterTower06_exports.blend has these display errors when the viewport is set to "look-dev" mode.
Added subscriber: @dineShinVa
Added subscriber: @nacioss
2 things, there is no attached blend file and please insert the missing information about your system setup and version of 2.8 build used. Thanks
This comment was removed by @dineShinVa
I don't get any glitch..have you tried with the latest 2.8 build?
The problem has actually worsened since newer releases. The most current release does not allow anything to be shown at all in "Look-Dev" mode except the outline of objects. This is true even for the startup file; the cube the scene starts with only appears as an outline. Remember, I am running Blender on a laptop. I suspect this has something to do with whether or not the hardware has a compatible GPU, which most laptops don't.
My Scene in Look-Dev:
New Scene (starter file) in Look-Dev:
Heyyyy...it works now! 05/16/19 release! Great work, devs!
Hash
2a9214eaaf
