Can't resize selected node #64693
8 Participants
Reference: blender/blender#64693
Operating system: Linux-4.15.0-47-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 390.116
Broken: version: 2.80 (sub 64), branch: blender2.7, commit date: 2019-05-15 21:16, hash:
989d854385
Broken: version: 2.80 (sub 64), branch: blender2.7, commit date: 2019-05-14 22:59, hash:
4e46ed37fc
Worked: version: 2.80 (sub 64), branch: blender2.7, commit date: 2019-05-13 22:40, hash:
f070bdd7c9
Added subscriber: @crantisz
#64939 was marked as duplicate of this issue
#64935 was marked as duplicate of this issue
#64880 was marked as duplicate of this issue
#64754 was marked as duplicate of this issue
#64696 was marked as duplicate of this issue
Added subscriber: @irfancelik
Added subscriber: @Gvgeo-1
Must be
af088c2640
change.Added subscribers: @WilliamReynish, @ideasman42, @brecht
This is same exact problem as in #64660… that one could be worked-around with a rather cheap trick, but current one am not sure…
This raises some more general design questions/issues in fact:
Question 2 is real root of the issue here, as node select, being a tool, gets precedence over all more specific/constrained operators (like link or resize, which both can only be triggered on much smaller 'active' areas than node selection itself). We can keep adding exceptions to select to abort in case we are also on node's border, but then this is sort of endless, terribly brittle, and prone to fail in more and more corner cases and special cases. I’d rather see a way developed to properly control priorities of evaluation of ops, think we'll need this more and more if we want to keep adding more and more things to a single event (left mouse click in that case).
@brecht, @ideasman42, @WilliamReynish this is kind of fundamental issue in current design imho… If you want lots of operators to use same shortcuts as init trigger, relying on PASSTHROUGH usage everywhere is really not the best way to go. If we don’t want to/can’t add a proper prioritization system, then I think we should at least review all those ops, to get some much, much stricter polling functions, instead of adding all kind of exceptions in their exec code?
Added subscriber: @iss
It should be possible to pass through events from
modal()
. Other modal operators just seem to returnPASSTHROUGH
withoutRUNNING_MODAL
. The latter only really needs to be returned frominvoke()
.As for order, I think resize should be ahead of selection in the keymap and it's not now? That's generally how I would expect things to work, operators in the right order in the keymap and passing through to the next one if not used.
Thing is, we also need passthrough from initial invoke call, since it’s init event here that is shared between ops. But we'd rather not have select ran at all if some other, more specific op can run instead, else getting rid of select running code (getting out of modal loop) won't be exactly easy.
And select being a tool, it is tried well before any other ops from regular keymap., at least from what I can see in
--debug-handlers
reports…This comment was removed by @Gvgeo-1
Added subscriber: @Oxer-1
@ideasman42 assigning to you to ensure you see that task, we really need input from event master here. Why do we break event handling when operator returns
(OPERATOR_PASS_THROUGH | OPERATOR_RUNNING_MODAL)
, at the end ofwm_handler_operator_call()
? This seems the opposite of PASSTHROUGH idea to me.Can’t see how we can do what we want to do here, currently… We need to keep events being processed after that initial call to
invoke()
has returned that combination of flags.Also, raising priority since that should be fixed asap imho.
In lack of a better idea, I’ll go rampaging
poll()
func of the select op to return false in case mouse is over a socket or node border, in a few days…Added subscriber: @nacioss
Added subscriber: @mont29
Closed as duplicate of #64935
Changed status from 'Duplicate' to: 'Open'
Added subscriber: @nobi08
Added subscriber: @JoshuaZacharias
Maybe related: Reroute dots can't be selected using standard select tool, only via box, lasso circle selcect tools.
This issue was referenced by
fd3f75a02c
