Can't generate particle hair edit 'comb cache' in blender 2.8 #64805
8 Participants
Reference: blender/blender#64805
Graphics card: GeForce GTX 660/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 416.94
Broken: version: 2.80 (sub 69), branch: blender2.7, commit date: 2019-05-17 23:36, hash:
03672e7783
Worked: blender 2.79
Can't generate particle hair edit data with simple script that goes into particle -edimode, and generates one brush stroke (worked in 2.79):
Cache is not generate. Poll error is thrown, but same steps work if executed manually.
Added subscriber: @JoseConseco
After digging bit more.
bpy.ops.particle.brush_edit() -this can generate particle edit cache ok if we are already in particle mode.
The problem is that if we are in obj mode, and in script switch to particle_edit_toggle() ('Particle') mode, then particle.brush_edit poll fails. I tried to call despgraph.update() before particle.brush_edit but it dosen't help.
Added subscribers: @Sergey, @lichtwerk
Can confirm, while polling (
PE_poll
,pe_get_current
),psys->edit
is NULLSome findings:
particle_edit_toggle_exec
):edit = PE_create_current(depsgraph, scene, ob);
PE_create_particle_edit
will also assign it to the psys:psys->edit = edit;
and the call tobpy.ops.particle.brush_edit
(not sure if this is all relevant and not sure how much of a temporary data
psys->edit
really is, this might all work as expected and bug might be somewhere else...)@Sergey: mind checking?
Added subscriber: @fclem
@fclem, team work time!
Part of the issue is that particle system is wrongly tagged for recalc. Caused by a mistake in runtime field initialization. Can be fixed by P1002: (An Untitled Masterwork)
However, after this is fixed i've got crash in depth drawing. Seems that
DRW_draw_depth_object()
expects mesh batch cache to be already allocated. However, this is not the case here: the object is tagged for geometry update when toggling particle edit mode. I guess is is where batch cache gets removed.Operator works fine because viewport is drawn prior to stroke and that ensures all needed batch caches.
@fclem, any chances you could look into this?
Added subscriber: @Jandals
@Sergey Can you still reproduce the crash? I can't reproduce it even if I checkout the original broken commit. I did test with and without your fix but it does not change the outcome of the operator poll function.
I tried with a debug build with and without asan.
@fclem, ugh, it was relying on
36faf739a7
which caused some issues and needs re-consideration.For this specific case i think you can safely use P1018 (just don't commit it). If you can solve the crash, i can then solve the issue with unintended hair reset.
The crash is fixed.
Thanks! Will have a look into solving the unwanted hair reset.
This issue was referenced by
e4df8b005f
Just to be clear, I do not really care about hair combing error when switching from object mode - to particle edit mode. I just wish there was way to generate particle hair 'comb cache', so that later I can write hair_key.co to it. Maybe it would be easier to make new operator for generatig particle comb cache ?
Well, this is a tricky call. In this case it seems it's easy to fix this particular case, especially since it's technically regression compared to 2.79. I do have D5162 which i will commit in a bit.
Added subscriber: @shash29-dev
Hi,
Using blender 2.91 and experiencing the same problem. Is the hair reset thing fixed?
A manual brush-stroke before toggling out of particle mode still seems to be necessary to keep the updated hair structure through a python script.
If done without the stroke, the hair structure is lost.
Is possible that the issue got re-introduced, as the particle system is a very fragile area.
Can you reproduce the issue with the steps and file from this report?
usc_head_vtxgp.blend
system-info.txt
alpha_test.py
strands00001.txt
Adding necessary files to reproduce the error. In the .py file's last line, toggling out of particle mode does the hair reset. If 102 line is commented, the hair structure is preserved but no cache is generated until a manual stroke is done.
Running the alpha_test.py with all other attached files in the working directory reproduces the issue.
I just tested original script from first post and it works ok (except api change for bpy.ops.particle.brush_edit , but cache is generated correctly)
I don't know what I am doing wrong. From the original script also, I keep on getting poll errors on brush_edit.
Is the hair reset issue is generated in the attached example (alpha_test) by running:
Please verify
If the initial report works fine, please submit a new bug report.
Added subscriber: @sydianchen
@Sergey Hi, I tested script of first post in Blender 3.1 and it raised one poll error as well. Is there any chance this error could be fixed again? I simply just want to find a way to write hairkey.co.
Anyway, I solved this comb cache problem by adjusting hair using this line of code:
Now I can change
co
as I wanted.
