Multi window spin tool crash #64998
Closed
opened 2019-05-22 18:26:05 +02:00 by Aurel P. · 23 comments
Graphics card: AMD Radeon(TM) R9 290X ATI Technologies Inc. 4.5.13542 Core Profile Context 25.20.14011.5005
Broken: version: 2.80 (sub 71), branch: blender2.7, commit date: 2019-05-20 22:03, hash: e787700393
Using Spin tool with two windows open (both in 3D Viewport) crashes Blender when going out of Edit mode or moving mouse cursor outside window
I have a dual monitor setup.
  1. Open Blender (optional step: File > Defaults > Load factory settings) > Window > New window
  2. Add a mesh
  3. enter Edit mode
  4. use Spin tool
  5. crash occurs when exiting Edit mode or moving the mouse cursor outside of the current window
It works fine with just one window open or if the second window is in another "Editor type"
Tested on both my work and home computers, same behaviour on all tested versions.
I download the latest build every few days and this issue is present on all the builds I have.
**System Information** Operating system: Windows-10-10.0.17763 64 Bits Graphics card: AMD Radeon(TM) R9 290X ATI Technologies Inc. 4.5.13542 Core Profile Context 25.20.14011.5005 **Blender Version** Broken: version: 2.80 (sub 71), branch: blender2.7, commit date: 2019-05-20 22:03, hash: `e787700393` Worked: (optional) **Short description of error** Using Spin tool with two windows open (both in 3D Viewport) crashes Blender when going out of Edit mode or moving mouse cursor outside window **Exact steps for others to reproduce the error** I have a dual monitor setup. 1. Open Blender (optional step: File > Defaults > Load factory settings) > Window > New window 2. Add a mesh 3. enter Edit mode 4. use Spin tool 5. crash occurs when exiting Edit mode or moving the mouse cursor outside of the current window It works fine with just one window open or if the second window is in another "Editor type" Tested on both my work and home computers, same behaviour on all tested versions. I download the latest build every few days and this issue is present on all the builds I have.
Author
Added subscriber: @peticel
Added subscriber: @Leon95
blender.crash.txt
Can Reproduce only after using the spin Tool. Other Tools or spin tool executed via search don't crash.
Operating system: Linux-4.4.0-148-generic-x86_64-with-debian-stretch-sid 64 Bits
Graphics card: Mesa DRI Intel(R) Sandybridge Mobile Intel Open Source Technology Center 3.3 (Core Profile) Mesa 18.0.5
[blender.crash.txt](https://archive.blender.org/developer/F7061288/blender.crash.txt) Can Reproduce only after using the spin Tool. Other Tools or spin tool executed via search don't crash. Operating system: Linux-4.4.0-148-generic-x86_64-with-debian-stretch-sid 64 Bits Graphics card: Mesa DRI Intel(R) Sandybridge Mobile Intel Open Source Technology Center 3.3 (Core Profile) Mesa 18.0.5
Added subscriber: @Gvgeo-1
I cannot reproduce here with 2019-05-22 85322737. Do you still get the crash?
Author
Operating system: Windows-10-10.0.16299 64 Bits
Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 416.81
CPU: AMD Threadripper 1950X
RAM: 64GB DDR4
Home PC: (since it is not specified in the initial post, maybe it matters)
CPU: Intel I7-4770K
RAM: 32GB DDR3
Broken: version: 2.80 (sub 71), branch: blender2.7, commit date: 2019-05-22 21:50, hash: a1ad71304c
Update with the latest build from my work PC
It no longer crashes when moving the mouse cursor outside the window (while using the Spin tool) but still crashes when going out of Edit mode.
Also, as Leon mentioned, executing the tool via Search works fine although I don't get the "controller?" (arc with two plus signs at the ends).
See first post
**System Information** Operating system: Windows-10-10.0.16299 64 Bits Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 416.81 CPU: AMD Threadripper 1950X RAM: 64GB DDR4 Home PC: (since it is not specified in the initial post, maybe it matters) CPU: Intel I7-4770K RAM: 32GB DDR3 **Blender Version** Broken: version: 2.80 (sub 71), branch: blender2.7, commit date: 2019-05-22 21:50, hash: `a1ad71304c` Worked: (optional) **Short description of error** Update with the latest build from my work PC It no longer crashes when moving the mouse cursor outside the window (while using the Spin tool) but still crashes when going out of Edit mode. Also, as Leon mentioned, executing the tool via Search works fine although I don't get the "controller?" (arc with two plus signs at the ends). **Exact steps for others to reproduce the error** See first post
Missed the 2 windows part the first time.
When finishing spin tool the operator return finish state correctly.
But when there are 2 windows, I see that the gizmo_tweak_invoke called again when exiting edit mode. Out of place cannot handle finish state and crashes.
Is it a duplication with the event system?
Missed the 2 windows part the first time. When finishing spin tool the operator return finish state correctly. But when there are 2 windows, I see that the `gizmo_tweak_invoke` called again when exiting edit mode. Out of place cannot handle finish state and crashes. Is it a duplication with the event system?
Brecht Van Lommel changed title from Spin tool crash on dual monitor setup to Multi window spin tool crash 2019-05-29 02:17:52 +02:00
Campbell Barton was assigned by Brecht Van Lommel 2019-05-29 02:17:52 +02:00
Added subscriber: @brecht
Possibly same cause as #63694 (Multi window measure crash).
Closed as duplicate of #63694
Added subscriber: @dfelinto
For the records, although this one seems related to #63694, this one I can reproduce from scratch (while the other I cannot). I think the cause may be different altogether.
Author
Hi.
Not sure if this is considered as fixed already.
Just so you know, this is still an issue in RC1.
Hi. Not sure if this is considered as fixed already. Just so you know, this is still an issue in RC1.
I can not reproduce this since the related fix was addressed. Could you revise if the "How to reproduce steps" are complete? (e.g., New Window or New Main Window, use spin tool in which one of the windows, ...)
Author
Hi Dalai.
The steps are same as before:
  1. Open Blender (optional step: File > Defaults > Load factory settings) > Window > New Window OR New Main Window ( tried them both )
  2. Add a mesh or use the default cube
  3. enter Edit mode
  4. use Spin tool ( **!!!very important!!!** - if I select the tool from the F3 search menu, it does not crash - only when selecting Spin from the tool shelf - T menu ) - crashes the same regardless of the window I use
Same behaviour on both work and home PCs
Hi Dalai. The steps are same as before: 1. Open Blender (optional step: File > Defaults > Load factory settings) > Window > New Window OR New Main Window ( tried them both ) 2. Add a mesh or use the default cube 3. enter Edit mode 4. use Spin tool ( `**!!!very important!!!**` - if I select the tool from the F3 search menu, it does not crash - only when selecting Spin from the tool shelf - T menu ) - crashes the same regardless of the window I use 5. crash occurs when exiting Edit mode Same behaviour on both work and home PCs
Confirmed:
SUMMARY: AddressSanitizer: heap-use-after-free //source/blender/windowmanager/gizmo/intern/wm_gizmo_group.c:562 in gizmo_tweak_modal
Full backtrace: P1038
Confirmed: `SUMMARY: AddressSanitizer: heap-use-after-free //source/blender/windowmanager/gizmo/intern/wm_gizmo_group.c:562 in gizmo_tweak_modal` Full backtrace: [P1038](https://archive.blender.org/developer/P1038.txt)
Author
Changed status from 'Duplicate' to: 'Open'
Aurel P. reopened this issue 2019-07-26 09:18:57 +02:00
Author
Hi again,
This is still an issue in RC3.
Same steps to reproduce as above.
Hi again, This is still an issue in RC3. Same steps to reproduce as above.
Added subscriber: @brinux
This is still crashing Blender to desktop with the release of Blender 2.8
Steps to reproduce are the same:
  1. open two windows
  2. go into edit mode
  3. use the spin tool from the icon shelf (not from the menu, but the icon shelf at the left)
  4. spin some verts
  5. exit edit mode and watch the crash to desktop
This is **still crashing Blender to desktop** with the release of Blender 2.8 Steps to reproduce are the same: 1) open two windows 2) go into edit mode 3) use the spin tool from the icon shelf (not from the menu, but the icon shelf at the left) 4) spin some verts 5) exit edit mode and watch the crash to desktop
Added subscriber: @xdanic
This issue was referenced by 82e719ff87
This issue was referenced by 82e719ff8764da6c48ba3de4e5c11226953002e8
9 Participants
Reference: blender/blender#64998
