Workspace tab behavior is buggy. #65084
Closed
opened 2019-05-24 20:30:41 +02:00 by Gavin Scott · 5 comments
Graphics card: GeForce GTX 1060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 419.17
Broken: version: 2.80 (sub 72), branch: master (modified), commit date: 2019-05-24 18:21, hash: 203f9a49e2
This is also not a brand new issue.
Nonsensical tab behavior when creating another instance of an existing tab type.
In a new General document, let's say you want a second workspace based on the initial default and currently active Layout workspace. If you use the /+\ button at the right end of the tabs and select General->Layout, then what happens is quite bizarre. A new tab gets added to the right end of the tabs as expected, but this new tab is linked to the existing Layout tab and it maintains the focus, while the old Layout tab on the left gets the new workspace name and links to the newly created workspace. This seems like a straight out bug that the two are reversed. The new tab should always be on the right with the newly created content and should receive the focus.
**System Information** Operating system: Windows-10-10.0.17134 64 Bits Graphics card: GeForce GTX 1060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 419.17 **Blender Version** Broken: version: 2.80 (sub 72), branch: master (modified), commit date: 2019-05-24 18:21, hash: `203f9a49e2` This is also not a brand new issue. **Short description of error** Nonsensical tab behavior when creating another instance of an existing tab type. **Exact steps for others to reproduce the error** In a new General document, let's say you want a second workspace based on the initial default and currently active Layout workspace. If you use the /+\ button at the right end of the tabs and select General->Layout, then what happens is quite bizarre. A new tab gets added to the right end of the tabs as expected, but this new tab is linked to the existing Layout tab and it maintains the focus, while the old Layout tab on the left gets the new workspace name and links to the newly created workspace. This seems like a straight out bug that the two are reversed. The new tab should always be on the right with the newly created content and should receive the focus.
Author
Added subscriber: @GavinScott
Added subscriber: @brecht
For the second bug there is already #61808 (Workspace appending is greyed out in Edit Mode). For user interface feedback, use devtalk.
This issue was referenced by 2a192624bc
This issue was referenced by 2a192624bc8419377c1966ff288b4e3ea529c192
Reference: blender/blender#65084
