Grease Pencil populate draw manager method is not called when Cycles Render mode with Overlays OFF #65191
Closed
opened 2019-05-27 18:07:48 +02:00 by Antonio Vazquez · 9 comments
Last source compiled at 27/05/2019
I have tested with prints the populate method and when set Cycles render and disable overlays, the method never is called.
I have tested with a simple Suzanne 2D
To reproduce.
  1. Open default scene
  2. Add Suzanne 2D
  3. Set to Cycles
  4. Set Render View mode
  5. Disable overlays
Last source compiled at 27/05/2019 I have tested with prints the populate method and when set Cycles render and disable overlays, the method never is called. I have tested with a simple Suzanne 2D To reproduce. 1) Open default scene 2) Add Suzanne 2D 3) Set to Cycles 4) Set Render View mode 5) Disable overlays
Author
Member
Added subscriber: @antoniov
#65051 was marked as duplicate of this issue
Brecht Van Lommel was assigned by Antonio Vazquez 2019-05-27 18:08:51 +02:00
Author
Member
Added subscribers: @fclem, @brecht
Author
Member
Not sure if this is for @brecht or @fclem because is related to Draw Manager.
Brecht Van Lommel was unassigned by Clément Foucault 2019-05-27 18:37:15 +02:00
Jeroen Bakker was assigned by Clément Foucault 2019-05-27 18:37:15 +02:00
Added subscriber: @Jeroen-Bakker
This was introduce by @Jeroen-Bakker If I recall correctly. Cycles without overlays skips the cache populate phase as it has no benefit from doing so. Maybe we need to add an exception for GPencil?
Member
Yes, that would be the cause.
The original idea was that we would limit the loop as it was not needed and add some speedup for heavy scenes.
The challenge is that in order to detect if GPencil is needed we have to loop over all objects and check if there is an GP object. The simple implementation will need to loop in average over 50% of the objects doing a Object type check.
I see the next options.
  1. Go back to the old situation. where objects are always looped over.
  2. Use the object_type_exclusion_filter. Not sure as this is quite hidden and GPobjects are visible by default.
  3. Add a precheck to see if we have any GPencil object.
  • Loop over all objects in the DEG scene and find out if there is any GPencil Object.
  • Building something like DEG statistics could remove the extra loop over the objects, but not sure we have such capability and if it fits in the DEG architecture. This can be used to remove the selection of GPencil Drawing engine at all.
@brecht What do you think would be the best solution for the 2.80 release?
I tried to come up with a solution that currently works, and limits the need to loop over the objects as much as possible with the current tooling. D4962
Yes, that would be the cause. The original idea was that we would limit the loop as it was not needed and add some speedup for heavy scenes. The challenge is that in order to detect if GPencil is needed we have to loop over all objects and check if there is an GP object. The simple implementation will need to loop in average over 50% of the objects doing a Object type check. I see the next options. 1. Go back to the old situation. where objects are always looped over. 2. Use the `object_type_exclusion_filter`. Not sure as this is quite hidden and GPobjects are visible by default. 3. Add a precheck to see if we have any GPencil object. - Loop over all objects in the DEG scene and find out if there is any GPencil Object. - Building something like DEG statistics could remove the extra loop over the objects, but not sure we have such capability and if it fits in the DEG architecture. This can be used to remove the selection of GPencil Drawing engine at all. @brecht What do you think would be the best solution for the 2.80 release? I tried to come up with a solution that currently works, and limits the need to loop over the objects as much as possible with the current tooling. [D4962](https://archive.blender.org/developer/D4962)
Member
Added subscribers: @asuralhp, @lichtwerk
Member
5 Participants
Reference: blender/blender#65191
