Error with paint curves and drawing with mouse buttons #65450
Reference: blender/blender#65450
system-info.txt
Broken: blender-2.80.0-git.cc600de6695a-windows64 (and probably above)
When using paint curves, they don't draw upon clicking the right mouse button if specified as the button to select with in the preferences. But they do if you set the mouse button to select with to be the left one. So if you have selected the LMB in the preferences then you can draw the paint curve (I don't mean creating the curve) with the LMB, but if you have chosen it to be the RMB then it doesn't work when pressing the RMB, neither does the LMB. (Also, the UI button for drawing the curve in the stroke panel does not work. But you can draw it when you type draw curve in the search panel)
Go to the Sculpting screen layout and create a paint curve on an object (if it helps, I used the the normal Draw brush). Open the Stroke panel in the Properties Editor and set the Stroke Method to Curve. If you have chosen the left mouse button in the Keymap section in the Blender Preferences under Select With: , then everything works fine. You can draw the paint curve on the object by doing a left click after creating it by doing multiple Ctrl-RMB clicks. But if you now set the mouse button with which you want to select to Right, then you can create the paint curve with Ctrl-LMB clicks, but when you try to sculpt/draw the paint curve with either the left mouse button or the right mouse button, none of them work. (And again, if you try to draw the paint curve with the Draw Curve UI button in the Stroke panel, it will also do nothing but turn blue because you clicked on it...)
Added subscriber: @MartinTheDragon
Uhm, I didn't mean to mention this, that is just the Blender version (?)
Added subscriber: @WilliamReynish
Added subscriber: @PabloDobarro
Testing this in 2.82:
Left click select:
Right click select:
@WilliamReynish What should we do with this? Should we add left click to the apply stroke left click select keymap or remove it from the other one?
Added subscriber: @EAW
Removing
Tracker Curfew
as @PabloDobarro has already retested and tagged it as aKnown Issue
