Menu and Splash screen problem #65552
Reference: blender/blender#65552
Operating system: Darwin-18.6.0-x86_64-i386-64bit 64 Bits (OS X 10.14.5)
Graphics card: Intel HD Graphics 4000 OpenGL Engine Intel Inc. 4.1 INTEL-12.9.22
Broken: version: 2.80 (sub 74), branch: blender2.7, commit date: 2019-06-04 22:32, hash:
e80cbdac33
Menu and Splash screen transparent. Preferences menu artifacts.
When Blender opens, the Splash screen appears transparent and the same happens with Menu. I tried to check preferences but I found some strange artifacts like strange lines from left bottom corner to where a checked box should be.
I uploaded three screenshots showing the problem.
Added subscriber: @Lakman
Added subscriber: @Jeroen-Bakker
Hi @Lakman
Did you had this problem also in previous versions of Blender2.80?
Can you tried to
Load Factory Settings
in case this is related to any transparency issues in the current theme.I would like to see the actual system-info to get better insight of the system you are running. Can you go to
Help
->Save System Info
and upload the file to this bug report?Hi
Thanks for the quick reply. The previous version of Blender 2.80 that I had downloaded about two or three weeks ago didn't have this problem. Anything looked to work fine. Unfortunately I didn't keep it to know which one was exactly.
system-info.txt
Did the
work?I was able to get similar results by changing the theme settings
If I change the alpha channel of
Themes
=>User Interface
=>Menu Back
=>Inner
to zero I get similar results for the splash screen and top menu.I am not able to get the same results as your preferences, but it seems like you loaded the non standard theme.
Added subscriber: @Memento
This is the exact same problem as #65383 , where a "Load Factory Settings" unfortunately doesn't change things. On a cleanly installed macOS machine with just Buildbot daily Blender 2.80 beta's installed.
Closed as duplicate of #65383
I tried Load Factory Settings but nothing happened. Also, all I see when I open preferences -->Themes --> User Interface --> Menu Back is the following screenshot. All options in Preferences menu seem to have almost disappeared.
