Threading problem with cycles when using CPU and GPU in blender 2.8 #65634
Reference: blender/blender#65634
Operating system: Windows 10 Professional
Graphics card: NVIDIA (MSI) Geforce GTX 1080 (without TI), 8 GB Grafic RAM
Grafic card driver: Official versions up to date. Currently in use a version from 2019.05.05 (Updating with "Geforce Experience")
CPU: Intel Core i7-6700K @about 4 GHz (4 real + 4 virtual CPUs)
RAM: 32 Gigabyte
!!! Video link showing the problem attached at the end !!!
Broken: all newer blender 2.8 versions (See my text at the end)
Worked: blender 2.8 from 2019.01.26 worked better but not perfect
Threading problem when using CPU + GPU randomly causes much longer calculation times in cycles
Describing an exact step is not possible. The problem occurs randomly. I try to describe it as best as possible:
I have created a huge project. It uses about 25 GB of RAM. I am rendering it with CPU + GPU in Blender 2.8. I tested with different tile sizes. Smaller sizes seems to force the problem faster, but all sizes create the problem. The GPU has only 8 GB RAM attached, so shared RAM is used additionally for the graphics card. I want to render preview pictures with cycles. So I selected samples = 4 for rendering only. Normally the computer takes a little bit over 3 Minutes for each picture. The CPU usage gets to 100 % and the GPU usage to about 90%. The GPU calculates its little quads much faster than the CPU. So there are some slow quads and one fast moving quad.
When I run the system for some time (over night) it happens very often that at the next morning each picture takes over 5 Minutes to calculate. The system gets in a situation that the GPU usage goes to 98%. But the GPU does not calculate the scene faster than the CPUs anymore. It seems that the GPU quad can not overtake the CPU quads anymore (or can not calculate several quads while the CPU calculates just one)
When I turn blender of and start it again (with the exactly same project and the exactly same options) it calculates fast again. For some time until this problem occurs again.
I have made videos of it with my smartphone, because when I try to make a video of the slow calculation, starting the video capture program suddenly "repairs" the situation. In my opinion this is an additional hint for a threading problem. For me it is possible to force the "threading" problem when I turn the priority of blender down in the task manager while calculating with CPU and GPU. But it is not guaranteed to get the problem. Sometimes it takes several hours to get it, sometimes it happens at the second picture I want to calculate. (But NEVER at the first one). Sometimes it helps to just start a YouTube Video to fix the blender problem or other programs. (But I can not sit the whole time next to my computer in the night to manually fix it by starting other programs ;) )
Very simple projects like just making a wall with so many sub surfaces, that it uses about the same amount of RAM does not trigger the problem. (Perhaps texture / shader transmission from shared RAM to GPU ram involved???)
This is the Video which shows the OK situation. You can see the quad of the GPU moving much faster than all the CPU quads. This is the situation I got after restarting blender with same project and same settings.
https:*youtu.be/E7MnZ9dQotI
This Video shows the situation when the threading problem occurs. This is how I found it at a morning after calculating over night. Same project, same options, only the characters moved a very little bit. Here all the quads seem to be equal slow and the task manager shows higher GPU usage.
https:*youtu.be/Vre4ePuwHOo
I have a Blender 2.8 version too from 2019.01.26. This version seems to be more robust. There I only get the threading problem when I change the CPU task priority in the task manager. But I can not use it because it has other problems. (Some colors are strange). I tested new versions starting from 2019.04.22 about every week, but the threading problem is in all new versions from blender. (The old version from 2019.01.26 is better but not perfect with the threading topic)
If you need further information just ask, I will try to help as much as possible. But I am not a blender developer. I am just a user of it. A guy from https://devtalk.blender.org/t/edit-blender-2-8-threading-problem-cycles-for-sure-videos-added/6897 told me to post the problem here too.
Edit: Perhaps it is important: I use Blender 2.79b for the modeling and Blender 2.8 for rendering. I keep the project for 2.79b and only load it with 2.8 for rendering. Even with the bug it is faster in 2.8. I can only use CPU in 2.79b, because the GPU ram is not enough and only 2.8 uses additional shared RAM.
Added subscriber: @Oskar_B
Added subscriber: @brecht
This is unlikely to be a threading problem I think, more likely an issue with GPU power management or priorities. It could be some kind of memory or resource leak, though I'm not sure if the problem can be triggered without running for a long time in some cases.
Are you rendering from the command line or the user interface? Does that make a difference? Does changing any power management setting for the graphics driver help?
The workaround would be to render individual frames from the command line.
Hi,
I only know how to use Blender with the Windows GUI. I had the power management idea too. I had set all windows power options to maximum (never go to sleep mode, never put monitor off... ) I did not look at energy options of the GPU. I looked now and found only one option, it is set to "optimal performance". I changed it now to "maximum performance". I will use that in the coming night for the test.
"Rendering individual frames" ... if I can select several frames to be rendered. I can not be up the whole night and start every frame individually. But I will try to find out how to use the command line with blender.
The older Version of Blender does not show this problem so much. My first question is: Was there a change regarding the Threading between 2019.001.26 and now (As the Version from April have the problems: Was there a change between January the 26th and April?)
I am not fully sure, but the problem seems not to happen when all scene data fits into the GPU RAM. I made a test with an old version of my project which uses only 7 GB RAM and there the problem did not happen. But it was only one single test over view hours.
"memory or resource leak". I has some blender crashes over night. (randomly too). Blender was just closed (whole program closed) at next morning. Just windows was running and doing nothing. No error message on screen, nothing. Only few pictures had been rendered. These crashes are rare. I had about 10 from January till now. (more with newer blender 2.8 versions)
The PC I use is my normal "gaming PC". Blender is just a hobby. So I run games with my PC (very very stable) too. So the PC itself has no problems like temperature problems. I would see that while playing games (e.g. Warthunder, Stellaris, Path of Exile, ...).
Edit1: The changed GPU setting did not help. The test directly showed it. First picture fast, second picture slow, even with "maximum performance" at GPU.
Edit2 And I was writing the "edit1" while the 3rd picture was calculated. I looked at the result and the 3rd picture was calculated fast again. So "fast, slow, fast" just random. But it NEVER change the speed while a single picture is rendering!!! only from one picture to the next one.
Used options:
Render
Viewport
Bake
If you need any other information please just ask!
Edit: Sorry for format. In the preview it looked good
For command line rendering, there is documentation here:
https://docs.blender.org/manual/en/latest/render/workflows/command_line.html
There are also batch render and render queue add-ons or standalone applications that help with this. The distinction here is important since there can be some tricks in the graphics drivers or operating system to keep GUI applications from using too many resources.
You can also check if renaming blender.exe to not_blender.exe makes a difference, sometimes there are application profiles that can interfere and this sidesteps them.
OK, I have testet the console now for about 7 hours. The "threading" problem does not appear there and it is faster in general.
I started it with
"blender -b D:\Models\test1.blend -a"
I hope this is correct. It uses CPU + GPU for sure (can be seen in task manager)
Result: (frame number, Time)
Frame1: 3:15
Frame2: 3:29 (OK some additional clear time I think)
Frame3: 3:31
Frame4: 3:32
Frame5: 3:32
Frame6: 3:37 (hmm ok)
Frame7: 3:33
Frame8: 3:32
Frame120: 3:43
Frame121: 3:43 (hmmm 10 seconds more in the meantime)
Restart Console!!!!
Frame122: 3:33 (a reduction about 10 seconds)
Frame123: 3:34 (this time the second frame not slower than first frame after console restart...!?!)
Frame124: 3:34
Test stop
The time differences like in the GUI version do not appear anymore. But I still think there is a threading problem. But now I think it is related to the Windows GUI only
Added subscriber: @Mets
Does this still need information from user?
I will say, a +/- 10 second variation in render time sounds normal to me. But the thing you initially described where your GPU appears to slow down massively, definitely doesn't! :)
Added subscriber: @iss
I will close this report, because it is too complex, while problem seems to be small variation in performance. Just running PC with windows is hardly controlled environment.
Please keep descriptions of issues short, ideally one sentence, provide steps to reproduce and .blend file for testing.
If you still have problems, I suggest to re-report with these guidelines in mind.
