VSE remaining UI inconsistencies #65845
Reference: blender/blender#65845
Here are some issues I found during working on manual:
Added subscriber: @iss
Added subscriber: @tintwotin
The contents of SEQUENCER_MT_change seems to have been moved into the Input menu in this commit: D2665
If the hidden elements(many different strip types and their options) all should be visible, but greyed out, it would be overkill. As it is now with a submenu changing contents depending on the current active strip will mean less clutter IMO, however image and sound strips does not have a sub-menu, because there are too few entries.
The major challenge in the VSE menus is to avoid they become that high that scrolling is needed to see the full contents. Currently the Strip menu is at maximum height(without scrolling) on a 1920x1080 screen:
Added subscriber: @WilliamReynish
I was a bit confused by this..
In a collective submenu for specific tasks for specific types there would be ~10 items, even if most would be grayed you can build "muscle memory".
@WilliamReynish is there convention for this? Or should I treat this as a bug?
Added subscriber: @Enetheru
Sorry if this is the wrong place to write this, but in the markers menu->jump to next marker, previous marker should instead be in the view->navigation menu instead with the other jump to commands?
Added subscriber: @brecht
There is some UI convention regarding this, though not exactly this case. In case of a boolean controlling the availability of something, it should be greyed out. For an enum it should switch between showing the buttons for each value, not grey out.
In this case I think hiding is ok.
Ideally the operator user interface names would indeed match. The operator names in the API should only be changed when really needed, since it breaks API compatibility.
We have a similar operator in the 3D viewport, though perhaps the naming could be better. There is a difference between a final render and a preview render using the viewport settings.
Sounds like a bug.
@iss - If you have a moment while going through the VSE functions when updating the manual, could you check the values in the "Timecode" Panel, if they make sense to you? For me, several of them do not. Here are my notes:
How I would expect the values to show:
The Strip and Hold values are the inside the strip values. These values are often referred to as player/source values:
The Playerhead value is labeled a bit misleading, because it is not the playhead position, but actually showing the duration between the playhead and the strip start. Maybe it should be called something like Time Measure or Duration to Start.
This used to toggle this on/off. The option is also in the timeline View menu, so maybe the operator hasn't been removed, but renamed?:
Where does this happen? In the Time panel?
If it is I'm posting this stuff here too which explains how I think the values in the Time panel should work:
Reading the manual text on the Time panel, I would like to add some words on how I think the values of the Time panel should have been for most usability:
Can you elaborate a bit more. Where do you see premultiply alpha? What needs to be done?
We can restore this functionality, but right now it's unused.
These changes can be done, but personally I would be happier if they were done in context of #59540 (VSE timeline manipulation API)
With great deal of luck I can start work on that task in next release, but it wont be priority.
With search https://docs.blender.org/api/master/search.html?q=alpha_mode&check_keywords=yes&area=default you can see where it is used.
What needs to be done is D5157: Move alpha_mode to color panel
