Eevee - Objects in front of SSS (Subsurface Scattering) shaded objects cause bluish dispersion #65849
7 Participants
Reference: blender/blender#65849
Windows 10 64-bit
Broken: 2.80 June 16, 01:02:51 -
87de71a8aaa
In Eevee, any objects occluding SSS shaded objects has bluish dispersion appearing at the point of occlusion.
Here's an example:
At first I thought it was a hair problem, but it's any object:
Should be easily reproducible by setting the values for SSS radius to be 1, 0, 0, and placing an object in front.
Also attaching the example file:2.8 MonkeyHairTest.blend
Added subscriber: @0o00o0oo
#71608 was marked as duplicate of this issue
This is a limitation of eevee's SSS. The occluders have infinite thickness.
@fclem Is there a good way around this problem? Or are there plans to remedy it?
As it stands, in situations like this, the results are sadly unusable.
We could add a thickness option for the SSS, similar to the one the SSR have.
Added subscriber: @jeacom
This is a terrible problem, it'll make SSS unviable for characters.
@fclem I'm not into shaders but isn't there a way to mask out the non-sss material pixels influence on the blurring kernel?
Edit:
It seems actually like they are already being masked but if I get it right the more non-sss pixels the blur kernel has to ignore, the darker is the resulting pixel, maybe if you normalize the resulting color relative to the amount of SSS pixels in the kernel?
@jeacom We cannot do this because we cannot distinguish between pixels that are unlit from pixels comming from another object at this point in the pipeline. The lighting is masked before doing the SSS passes.
But the idea is good and that's what we will eventually do if we can in the future.
This comment was removed by @jeacom
@fclem just noticed that if we enable SSS on the occluder's material and set the SSS radius to 0, the problem goes away, presumably because the lighting mask gets disabled on the occluders?
Because the lighting does "bleed" from the occluder to the SSS object. This becomes a problem when the occluder recieves more light than the occludee.
oh, I see.
So the color is being applied before the blur, not after.
If I enable separate albedo, the light bleeding disappears tho.
At least it looks viable to disable the light mask if sepparate albedo is enabled, this would fix the problem at the cost of the texture blur right?
I personally think the result looks better with separate albedo enabled anyway.
I am convinced that if separate albedo is on, the best is to not mask the lighting.
Added subscriber: @Stober-3
It's unfortunate this task was closed as "invalid". Shouldn't it be left open until a solution can be found?
As it stands, it's a clear visual problem. I'm afraid being marked as "invalid" simply buries the issue and prevents a prompt to resolve it (unless this limitation is noted somewhere as problematic).
Added subscriber: @Raimund58
Added subscriber: @geocentric_wage
Removed subscriber: @geocentric_wage
