Custom property error: bpy.app.use_library_override #65922
Closed
opened 2019-06-19 10:58:26 +02:00 by Fabian Ruch · 6 comments
Operating system:
Graphics card:
Broken: .80, 1dab26afb9, 2018-06-19
Changeing properties of bones cause errors and links in drivers break
Create a Armature
Select the existing bone
Enter Pose mode
Select Bone in the Property window
Add a custom property
Edit the property
When confirming the change a lot of errors occur.
Everything seems to work, except that connections to drivers will break as well.
**System Information** Operating system: Graphics card: **Blender Version** Broken: .80, 1dab26afb9c8, 2018-06-19 Worked: (optional) **Short description of error** Changeing properties of bones cause errors and links in drivers break **Exact steps for others to reproduce the error** Create a Armature Select the existing bone Enter Pose mode Select Bone in the Property window Add a custom property Edit the property When confirming the change a lot of errors occur. Everything seems to work, except that connections to drivers will break as well.
Author
Added subscriber: @fabian.ruch
Added subscriber: @brecht
I can't reproduce this.
Can you attach a .blend file where just editing the property gives an error? And what is the error message then?
I can't reproduce this. Can you attach a .blend file where just editing the property gives an error? And what is the error message then?
Author
blendererror.blend
Of course.
I also added the error message and a picture where I exactly changed the custom property
![blendererror2.png](https://archive.blender.org/developer/F7267001/blendererror2.png) ![blendererror.png](https://archive.blender.org/developer/F7266892/blendererror.png) [blendererror.blend](https://archive.blender.org/developer/F7266837/blendererror.blend) Of course. I also added the error message and a picture where I exactly changed the custom property
Bastien Montagne was assigned by Brecht Van Lommel 2019-06-19 17:54:13 +02:00
Brecht Van Lommel changed title from Bone Propertie change causes error to Custom property error: bpy.app.use_library_override 2019-06-19 17:55:22 +02:00
This issue was referenced by 79bd5174e4
This issue was referenced by 79bd5174e47d75e19564da921867958eaad25243
Reference: blender/blender#65922
