Selecting/Moving Beveled, Modifier'd Curve Vertex -> Crash #65981
Closed
opened 2019-06-21 02:19:26 +02:00 by Finn Bear · 3 comments
Operating system: Linux-4.15.0-50-generic-x86_64-with-debian-buster-sid 64 Bits (Ubuntu 18.04)
Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 410.104
2.80 (sub 74), branch: master, commit date: 2019-06-19 18:29, hash: d30f72dfd8
Blender crashes when a curve/path that has been beveled and has any modifier (I tried mirror and edge split) has a vertex selected in edit mode.
Here is the stacktrace from the first time I encountered the issue:
Blender 2.80 (sub 74), Commit date: 2019-06-19 18:29, Hash d30f72dfd8ac
Saved "propeller-plane-2-2.blend"  # Info
bpy.context.space_data.show_restrict_column_render = True  # Property
bpy.context.space_data.show_restrict_column_viewport = True  # Property
bpy.data.screens["Layout"].shading.type = 'MATERIAL'  # Property
bpy.data.screens["Layout"].shading.type = 'SOLID'  # Property
Saved "propeller-plane-2-3.blend"  # Info
bpy.ops.object.editmode_toggle()  # Operator
...lots of other lines...
bpy.data.objects["Ailerons"].hide_viewport = False  # Property
bpy.data.objects["Ailerons"].hide_render = False  # Property
bpy.context.scene.camera = bpy.data.objects["Camera"]  # Property
bpy.context.space_data.context = 'MATERIAL'  # Property
backtrace
/home/finnb/Downloads/Software/blender-2.8/blender(BLI_system_backtrace+0x1d) [0x138312d]
/home/finnb/Downloads/Software/blender-2.8/blender() [0x11697b9]
/lib/x86_64-linux-gnu/libc.so.6(+0x3ef20) [0x7ff83e13ef20]
/home/finnb/Downloads/Software/blender-2.8/blender() [0x2a3d802]
/home/finnb/Downloads/Software/blender-2.8/blender() [0x2a40284]
/home/finnb/Downloads/Software/blender-2.8/blender() [0x2a36811]
/home/finnb/Downloads/Software/blender-2.8/blender(DRW_draw_render_loop_ex+0x333) [0x2a37c23]
/home/finnb/Downloads/Software/blender-2.8/blender(view3d_main_region_draw+0x77) [0x2cfe2c7]
/home/finnb/Downloads/Software/blender-2.8/blender(ED_region_do_draw+0x851) [0x2d71121]
/home/finnb/Downloads/Software/blender-2.8/blender(wm_draw_update+0x462) [0x152ffd2]
/home/finnb/Downloads/Software/blender-2.8/blender(WM_main+0x30) [0x152d7a0]
/home/finnb/Downloads/Software/blender-2.8/blender(main+0x30a) [0x10cfb1a]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7ff83e121b97]
/home/finnb/Downloads/Software/blender-2.8/blender(_start+0x2a) [0x11660ea]
The following may be unrelated but I'm seeing it in the console when I toggle edit mode (one time per edit mode toggle)
Using fallback
Using fallback
Using fallback
Exact steps for others to reproduce the error the way I did
  • Here is the blend file propeller-plane-2-3.blend
  • Select the curves/paths within the plane's cockpit (they are mirrored and look like a roll-cage on a car)
  • Enter edit mode
  • If it doesn't crash already, select a vertex of the curve/path
Exact steps for others to reproduce the error from scratch
  • Add a path object
  • Add a mirror/edge split/etc. modifier
  • Add a bevel depth
  • Enter edit mode
  • Select any vertex
  • If it doesn't crash already, try translating the vertex
**System Information** Operating system: Linux-4.15.0-50-generic-x86_64-with-debian-buster-sid 64 Bits (Ubuntu 18.04) Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 410.104 **Blender Version** 2.80 (sub 74), branch: master, commit date: 2019-06-19 18:29, hash: `d30f72dfd8` **Short description of error** Blender crashes when a curve/path that has been beveled and has any modifier (I tried mirror and edge split) has a vertex selected in edit mode. Here is the stacktrace from the first time I encountered the issue: ``` Blender 2.80 (sub 74), Commit date: 2019-06-19 18:29, Hash d30f72dfd8ac Saved "propeller-plane-2-2.blend" # Info bpy.context.space_data.show_restrict_column_render = True # Property bpy.context.space_data.show_restrict_column_viewport = True # Property bpy.data.screens["Layout"].shading.type = 'MATERIAL' # Property bpy.data.screens["Layout"].shading.type = 'SOLID' # Property Saved "propeller-plane-2-3.blend" # Info bpy.ops.object.editmode_toggle() # Operator ...lots of other lines... Saved "propeller-plane-2-3.blend" # Info bpy.data.objects["Ailerons"].hide_viewport = False # Property bpy.data.objects["Ailerons"].hide_render = False # Property bpy.context.scene.camera = bpy.data.objects["Camera"] # Property Saved "propeller-plane-2-3.blend" # Info bpy.context.space_data.context = 'MATERIAL' # Property bpy.ops.object.editmode_toggle() # Operator backtrace /home/finnb/Downloads/Software/blender-2.8/blender(BLI_system_backtrace+0x1d) [0x138312d] /home/finnb/Downloads/Software/blender-2.8/blender() [0x11697b9] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20) [0x7ff83e13ef20] /home/finnb/Downloads/Software/blender-2.8/blender() [0x2a3d802] /home/finnb/Downloads/Software/blender-2.8/blender() [0x2a40284] /home/finnb/Downloads/Software/blender-2.8/blender() [0x2a36811] /home/finnb/Downloads/Software/blender-2.8/blender(DRW_draw_render_loop_ex+0x333) [0x2a37c23] /home/finnb/Downloads/Software/blender-2.8/blender(view3d_main_region_draw+0x77) [0x2cfe2c7] /home/finnb/Downloads/Software/blender-2.8/blender(ED_region_do_draw+0x851) [0x2d71121] /home/finnb/Downloads/Software/blender-2.8/blender(wm_draw_update+0x462) [0x152ffd2] /home/finnb/Downloads/Software/blender-2.8/blender(WM_main+0x30) [0x152d7a0] /home/finnb/Downloads/Software/blender-2.8/blender(main+0x30a) [0x10cfb1a] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7ff83e121b97] /home/finnb/Downloads/Software/blender-2.8/blender(_start+0x2a) [0x11660ea] ``` The following may be unrelated but I'm seeing it in the console when I toggle edit mode (one time per edit mode toggle) ``` Using fallback Using fallback Using fallback ``` **Exact steps for others to reproduce the error the way I did** - Here is the blend file [propeller-plane-2-3.blend](https://archive.blender.org/developer/F7404044/propeller-plane-2-3.blend) - Select the curves/paths within the plane's cockpit (they are mirrored and look like a roll-cage on a car) - Enter edit mode - If it doesn't crash already, select a vertex of the curve/path **Exact steps for others to reproduce the error from scratch** - Add a path object - Add a mirror/edge split/etc. modifier - Add a bevel depth - Enter edit mode - Select any vertex - If it doesn't crash already, try translating the vertex
Author
Added subscriber: @finnb
Finn Bear changed title from Random Crash During Mesh/Camera Editing [Incomplete] to Selecting/Moving Extruded, Mirrored Curve Vertex -> Crash 2019-06-21 02:35:16 +02:00
Finn Bear changed title from Selecting/Moving Extruded, Mirrored Curve Vertex -> Crash to Selecting/Moving Beveled, Modifier'd Curve Vertex -> Crash 2019-06-21 02:39:01 +02:00
Author
Finn Bear self-assigned this 2019-06-21 02:53:20 +02:00
Author
I downloaded 2.8 from June 20th and the issue is resolved :)
1 Participants
Reference: blender/blender#65981
