shortcut conflict #65994
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#65994
In latest builds of 2.8 cut links shortcut changed in sgader editor. Now this shoortcut dont work with node wrangler addon.
Operating system:
Graphics card:
Broken:
(example: 2.79b release)
Added subscriber: @EDUART
Added subscriber: @MaciejJutrzenka
do you mean this problem?
https://developer.blender.org/T65956
I mean if u in shader editor and wanted to cut links it was CTRL+LMB. In latest builds shortcut changed to CTRL+RMB. but if u activate node wrangler addon and press CTRL+RMB u will not be able to cut links. because ctrl+rmb it is lazy connect in node wrangler and u cant change shortcuts in this addon
Added subscriber: @billyand
Added subscriber: @BrendonMurphy
I believe this issue is resolved. Node wrangler keymaps have been recently changed. Feel free to re-open if this is not the case. testing should be done with rc2
