Non-active Grease Pencil object stuck in draw mode #66126
Reference: blender/blender#66126
Graphics card: GeForce GT 710/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 416.94
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-06-24 18:46, hash:
c0c1b4542f
Unable to select, edit object or draw.
not sure how this error was produced since i didnt tamper with any setting.
brokenGpencil.blend
Added subscriber: @Ryu_Vector
Added subscribers: @antoniov, @dfelinto
The object in question is stuck in the 'PAINT_GPENCIL' mode.
I tried to reproduce it from scratch and fail. Can you recall what you were doing before this issue?
Quick user support: You can fix this if you type in the blender console editor:
C.view_layer.objects.active = D.objetcs['GPencil.001']
Added subscriber: @ideasman42
Actually I managed to reproduce it:
[run a release build otherwise you will run in a
BLI_assert failed: //source/blender/windowmanager/intern/wm_toolsystem.c:86, WM_toolsystem_ref_from_context(), at 'tref == sa->runtime.tool'
assert - cc @ideasman42 ]Collection
.Now you can not make the object active because it is stuck in the draw mode. The same does not happen with mesh objects.
Broken Grease Pencilto Non-active Grease Pencil object stuck in draw mode@antoniov the issue here is that greasepencil is treated as a special case and fails to leave draw mode when we call e.g., ED_object_mode_generic_exit().
I addressed this partially by setting the mode to object mode when the object is not active on load time (ED_editors_init()).
However a proper fix need to account for
do_outliner_item_activate_tree_element()
anded_object_select_pick()
as well. So if users run into this mid-section things still work.I believe that if we integrate greasepencil in ED_object_mode_generic_exit() most of the issues go away.
@dfelinto Proposed fix in D5138
I have tested and the bug has gone.
This issue was referenced by
4f3f68df30
