Eevee contact shadows cause light bleeding around occluded objects #66139
7 Participants
Reference: blender/blender#66139
Operating system: Win 10 64 bit
Graphics card: GTX 1080 ti
Broken: 2.80,
12da679fa0
, 2018-06-16Short description of error
Contact shadows cause weird light shafts to appear around occluded objects.
.blend showing problem: test.blend
Watch video explaining the problem
Weird light shafts should appear around object on floor.
I've tried making the cube walls thick, or adding large objects on other side of the wall. But the problem persists.
I know there are many limitations of eevee that can cause light bleeding. But this is persistent, leading me to think it's a bug.
Added subscriber: @AndrewPrice
Added subscriber: @filibis
Added subscriber: @muratagawa
Added subscriber: @raitz
Added subscriber: @moisessalvador
Contact shadows are screen space. They have the typical limitations of the other screen space things like AO and reflections. The thickness of the wall behind doesn't exist as far as screen space is concerned. I barely use them because of that and other limitations with thin object.
Do you want proper watertight shadows with real contact hardening and area penumbra? What I like to do is go to the Shadows panel in the render properties and change ESM to VSM, increase the cube size for better precision, and turn on high bitdepth and soft shadows. Then I go to each lamp, turn Softness to 0, since I'm using real soft shadows now. And turn bias to 0 and bleed bias to 0.5 or more. These are the closest to raytraced shadows you will get. And adding thickness to walls works with this method. You can still combine this with screen space contact shadows too
Added subscriber: @lichtwerk
Added subscriber: @fclem
@fclem: does this count as known limitation?
Known limitation. Hopefully one day we will have raytraced shadows.
