bevel numeric input not working correctly with scene units #66204
Closed
opened 2019-06-28 09:42:52 +02:00 by Christian Vogel · 5 comments
Operating system: Windows 10 1903
Graphics card: RTX2060
Broken: blender-2.80-155c62b070a9-win64
Worked: -
bevel does not use correct numeric input when units are switched
choosing cm in scene > units > length does not map correctly when using numeric input with beveling (ctrl+e in edit mode): pressing 1 on keyboard results in 100 cm
This problem does not exist with inset and other operations afaik
**System Information** Operating system: Windows 10 1903 Graphics card: RTX2060 **Blender Version** Broken: blender-2.80-155c62b070a9-win64 Worked: - **Short description of error** bevel does not use correct numeric input when units are switched **Exact steps for others to reproduce the error** choosing cm in scene > units > length does not map correctly when using numeric input with beveling (ctrl+e in edit mode): pressing 1 on keyboard results in 100 cm This problem does not exist with inset and other operations afaik
Added subscriber: @akaChris
Jacques Lucke was assigned by Brecht Van Lommel 2019-06-28 15:19:57 +02:00
Member
Added subscriber: @howardt
Member
@howardt This can be fixed with the following change. Is the same unit used for other properties as well (haven't checked the code in detail). Feel free to commit the fix when it is correct.
diff --git a/source/blender/editors/mesh/editmesh_bevel.c b/source/blender/editors/mesh/editmesh_bevel.c
index 78b4cfe38d4..10fadc6a1b3 100644
--- a/source/blender/editors/mesh/editmesh_bevel.c
+++ b/source/blender/editors/mesh/editmesh_bevel.c
@@ -270,7 +270,7 @@ static bool edbm_bevel_init(bContext *C, wmOperator *op, const bool is_modal)
       opdata->num_input[i].unit_sys = scene->unit.system;
     /* Not sure this is a factor or a unit? */
-    opdata->num_input[i].unit_type[0] = B_UNIT_NONE;
+    opdata->num_input[i].unit_type[0] = B_UNIT_LENGTH;
   /* avoid the cost of allocating a bm copy */
@howardt This can be fixed with the following change. Is the same unit used for other properties as well (haven't checked the code in detail). Feel free to commit the fix when it is correct. ``` diff --git a/source/blender/editors/mesh/editmesh_bevel.c b/source/blender/editors/mesh/editmesh_bevel.c index 78b4cfe38d4..10fadc6a1b3 100644 --- a/source/blender/editors/mesh/editmesh_bevel.c +++ b/source/blender/editors/mesh/editmesh_bevel.c @@ -270,7 +270,7 @@ static bool edbm_bevel_init(bContext *C, wmOperator *op, const bool is_modal) opdata->num_input[i].unit_sys = scene->unit.system; } /* Not sure this is a factor or a unit? */ - opdata->num_input[i].unit_type[0] = B_UNIT_NONE; + opdata->num_input[i].unit_type[0] = B_UNIT_LENGTH; } /* avoid the cost of allocating a bm copy */ ```
This issue was referenced by 7c8bf77e13
This issue was referenced by 7c8bf77e1351f5e44b28cb930c3b4c46589bc5ae
Member
Reference: blender/blender#66204
