bug in sapling tree_gen #66252
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#66252
Operating system: Linux Mint Cin. 18.3 64bit
Graphics card: Nvidia 660GTX
Broken: 2.80 (sub 74), branch: master, commit date: 2019-06-29 14:01, hash: f566212aa237, type: Release
build date: 2019-06-29, 16:14:14
error when add a tree with the sapling tree_gen addon.
same like here: https://developer.blender.org/T65025
by default start, delete the cube and add a plane => then add curve => sapling tree_gen = error!
Added subscriber: @Pinus
Added subscriber: @StephenSwaney
Cannot reproduce on Linux with the 6-29 daily build.
Curious that you are getting an error about a Cube.
Do you have the problem if you start with factory settings?
Hello Stephen;
When i setup a new install of the same blender-version in a new folder and start, i get the same error.
Then i load the factory-settings, and the problem seems solved => SaplingTree works... so far so good...
But when i activate some addons the bug is back!
I have activated and deactivated the addons to find out wich one is the bad-guy, but nothing changes.
Only when i load the factory-settings SaplingTree works.
I have also tested the last blender build from today (2.80 Beta Linux 64 bit June 29, 23:04:38 - be060c3990ad
but same effects; factory settings works, but after activate some addons the bug is back.
On win 8.1 64bit no problems with the last 3 2.8 builds, seems like only linux is affected.
Here my .blend file with the bug:
test_bug_sapling_tree_gen.blend
Added subscriber: @CansecoGPC
I can't reproduce this bug on Linux with the steps you mention, except if i add fake user to the cube before deleting it.
I made a patch that should solve this problem soon.
thx, Canseco.
btw: how to delete a fake user?
i found a workaround to fix? the problem on my second linux-machine with the same bug:
(nothing to save but necessary...) close blender.
i did the same steps on my first-linux-machine and it works so far, but now my DecalMachine addon
loads the preview-icons extremely slow (when pressing D) (before fixing it loads immediately)
i think this is not a blender bug, but a interesting effect, because removing the addon and cleaning all folders and reinstall
did not solve the problem (i will contact the developer...)
have someone else the same problem withDecalMachine 1.8.6 ?
