Changing Cycles Render Devices CUDA device selection does not mark prefs dirty
Closed, DuplicatePublic
Graphics card: GeForce GTX 1060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 419.17
Broken: version: 2.80 (sub 74), branch: master (modified), commit date: 2019-07-01 14:26, hash: rBa6fe4d112ff4
In System Preferences for Cycles Render Devices, switching between None/CUDA/OpenCL marks the preferences as dirty for auto-save, however changing the specific device choices within say CUDA does not. So if your saved prefs have only your GPU enabled for CUDA and you check the CPU box as well, then this change will not be persistent.
Default config.
Open Preferences editor.
In the hamburger menu disable auto-save and click Save Preferences so we can watch the button to see the state of the dirty flag.
In System, Change Cycles Render Device from None to CUDA, and note that the Save Preferences button gets enabled indicating the prefs are now dirty.
Click Save Preferences to mark things clean again.
Change one or more of the device check-boxes for specific CUDA devices (enable the CPU device for example) and note that the Save Preferences button does not enable, indicating these changes are not marking preferences as needing to be saved.
It seems that some Cycles preferences are not being saved.
I don't have any GPU device that supports either CUDA or OpenCL to test.
@Brecht Van Lommel (brecht), can you take a look?
I can confirm that the same happens for the OpenCL part too. So I think this is just a generar settings things and not CUDA related.
Sebastian Parborg (zeddb) lowered the priority of this task from 90 to 50.Jul 3 2019, 5:23 PM
