Node Arrange #66410
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#66410
hi, this addon does nice arrangements of node trees. Currently does not support node trees inside groups. Works far better than the current arrange in node wrangler.
node_arrange.py
Added subscriber: @BrendonMurphy
Added subscriber: @WilliamReynish
Nice. IMO this should even just be a built-in feature. Other apps with nodes have this included by default.
Thanks @WilliamReynish, That sounds sensible. It's still pretty bare bones, does not work in all node editors. I was working with the author when he designed it and mostly needed for materials nodes for my mat libraries.
This update is from Vilem Duha, Original by JuhaW, We have full permissions to take it on.
Well, if you get it to work well for all editors, it could go through review as a built-in feature I think.
We can try this in the near future.
Zipped file, cleaned up code, works across all node editors afaict.
node_arrange.zip
node_arrange.py
added gpl
Added subscriber: @povmaniac
Work nicely with TheBounty renderer nodes..
Added subscribers: @JacquesLucke, @VilemDuha
node_arrange.py
New file, some tidy up, added arrange code from node wrangler to help with unconnected nodes and align to selected.
There was a limitation with unconnected nodes, the "Align to Selected" helps greatly with this.
Current limitation does not work inside node groups. Same with the node wrangler align.
Those of us in the know have been using this addon for some time now, (years). I've tested with animation nodes and across all built in node editors and custom node editor types. Only recently after an update by @VilemDuha iirc, did I decide it was time release properly. We shouldn't hold this back.
@WilliamReynish currently the code here is good enough for an addon and the purpose of getting the job done. It's not good enough to be a built in function. A built in function would need to be done properly by an expert in nodes.
I would like to add this to release addons. The whole purpose of this task was to give the general users access to this very nice tool. I think this is a good case that we should release this code until such time as it's done properly as a built in function, then remove the addon.
@JacquesLucke I would like to know your opinion here also. Thanks.
node_arrange.py
Added basic poll to disable the ui if no nodes in an editor. example is Texture node editor was reporting errors if there were no active nodes.
node_arrange.py
Fixes for Select Unlinked working in all editors thanks JuhaW (TynkaTopi) for his help and for this awesome addon.
Closing as resolved.
