Import-Export AutoCAD DXF Format (.dxf) #66485
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
5 Participants
Reference: blender/blender-addons#66485
Hi,
I'm new to blender.
I would like to import a dxf file but I cannot enable the option under Blender User Preferences > Add-on > Import-Export AutoCAD DXF format.
How can I solve this issue?
Any help would be much appreciated
Many thanks
Alex
Operating system:
Graphics card:
Broken:
(example: 2.79b release)
Added subscriber: @AlexisCh
Added subscriber: @EitanSomething
Currently Import-Export AutoCAD DXF Format (.dxf) is being updated for 2.80. Quick question, is it an option at User Preferences > Add-on > Import-Export AutoCAD DXF format or just doesn't work?If it isn't showing up make sure the community tab is enabled.
Hi,
Thanks for your email,
It is exactly the option you mentioned. I can tick the option but then it never shows up when I'm trying to import a file.
I've tried also version 2.80 and I'm experiencing the same issue
Many thanks
Alex
Does it work with 2.79
It doesn't work with 2.79. it doesn't work with 2.80. i tried both versions
In 2.80 and 2.79b you can only export not import.Is exporting as DXF an option in 2.79b as well as 2.80?
Added subscriber: @StephenSwaney
Looking at my 2.80 daily, I see TWO separate addons for DXF, one for IMPORT and one for EXPORT.
Each one shows up in the appropriate File->Import or File->Export menu.
Same with 2.79b release.
Given that you did not mention any particular version, I suggest you
I'm using 2.80 now which is the latest release but I've tried also 2.79b before.
Import DXF option is not showing up in File >Import > AutoCAD.DXF even if I enable IMPORT DXF addon
The option under the Add-on is grayed out and even if I tick the box, IMPORT DXF would not be visible in File >Import > AutoCAD.DXF.
Please see attached below.
Edit
I'm very sorry, I was enabling the export option only that's why I couldn't see DXF under the Import option.
Problem is now solved.
I feel embarrassed for stealing your time for such an easy point.
Many thanks for your help
Alex
In your addon screenshot, it says
Description: This script exports geometry to DXF format
You have the export addon enabled.
Thanks very much Stephen,
my mistake.
Glad it's working. Blender on!
Changed status from 'Resolved' to: 'Archived'
Added subscriber: @jumaku87
Does export addon work with anyone anymore?
I can't get it work with 3.0, 3.1 or 3.2 versions.. but in 2.83 and 2.93 it does work.
Added subscriber: @larkinja
I'm also wondering if this function is still working. I really need to get dxf files out of blender. The import and export addons will enable and it shows up in the export options, but when I give it a name and hit export, no file is created. As a workaround I figured I could export an svg and then bring it into fusion to create a dxf file, but my svg file that is created is 1k and seems to be empty as it won't import into fusion. Any thoughts or help?
