Runtime syntax error when attempting to select object #66885
5 Participants
Reference: blender/blender#66885
Operating system: Windows 10
Graphics card: GTX 1050 Ti
version: 2.80 (sub 74), branch: master, commit date: 2019-06-29 20:58, hash:
be060c3990
, type: Releasebuild date: 29/06/2019, 17:58
Edit:
shading.show_xray
/ Shading option toggle buttons at the top right and clickassign shortcut
and left click (Or right click depending on your select key map) inside thePress a key
button ( Image: https://xavie.ru/i/2jee3et.png )After exporting the keymap, this can be found:
Added subscriber: @xaviergmail
I've upgraded to the latest 2.8 RC build and the issue persists.
Added subscriber: @GavinScott
To get the Assign Shortcut to work properly, you need to never click on the Press a Key button, as doing so will try to assign the mouse click as the shortcut, hijacking your left (or right) click action which generally makes a mess out of things, and you're prevented from changing it back as you saw.
Just pass the mouse over the pop-up which will cause it to switch to the blue Press a Key state at which point you can press the key that you want to have as the shortcut, and things should work without issue.
We really should do something to stop people from clicking on that thing!
Absolutely agree on adding at least some sort of warning or confirmation popup.
I was unable to remove the keybinding from my settings afterwards. I tried exporting the keymap, removing the defunct bind and re-importing, but the bind still persisted so I resorted to clearing out my user settings entirely and started anew. Thankfully I hadn't done much customization.
Closed as duplicate of #65397
Added subscriber: @Destic
Just made an account to add this little piece. You can fix it by going to Edit->Preferences->Keymap. Then open the "Window" Tab and go to the bottom of it. The "Context Toggle" is the accidental shortcut that was set for the Xray. Remove it and everything should work again. This way you don't have to remove everything you've previously added (if you haven't saved your settings before that is). This doesn't happen because of left or right clicking, its happens with any shortcut you try to assign to the Xray Toggle via rightclicking the setting & assigning it.
If you want to set a Shortcut for the Xray Toggle, just write "xray" into the searchbar of the Keymap page and you'll find it.
Added subscriber: @rdllngr
Same problem:
When I try to assimilate a keyboard shortcut to X-Ray via rightclicking, Blender brings me back to this error in the image below after executing the shortcut.
The solution I found:
I couldn't get results for "xray" in Keymap searchbar, however I was able to create the shortcut manually in Keymap > Window > Add New with the Context Attribute space_data.shading.show_xray (see below):
The only problem is that it only works on solid mode. Now how do I get it to work in wireframe mode too?
