Unable to add previously closed workspace from the menu bar #67005
Closed
opened 2019-07-15 18:08:35 +02:00 by Ramkrishna Verma · 9 comments
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.86
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-11 13:50, hash: 06312c6d2d
On opening blender, in the default scene, when I delete one of the available workspaces, then on trying to add them back from the menu bar doesn't work. That workspace is removed from the menu bar.
  • Open blender. The default startup opens with the default scene.
  • In the menu bar from the available workspaces, Right-Click on one of the workspaces e.g Animation.
  • From the context menu that opens, select Delete. The workspace is removed from the menu bar.
  • Click on the Add Workspace button.
  • Then from the menu that opens, select General => [Workspace that was deleted previously]. In this case it was Animation.
  • Notice that the workspace is not added.
This is happening in the default startup.
**System Information** Operating system: Windows-10-10.0.18362 64 Bits Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.86 **Blender Version** Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-11 13:50, hash: `06312c6d2d` Worked: (optional) **Short description of error** On opening blender, in the default scene, when I delete one of the available workspaces, then on trying to add them back from the menu bar doesn't work. That workspace is removed from the menu bar. **Exact steps for others to reproduce the error** - **Open blender**. The default startup opens with the default scene. - In the menu bar from the available workspaces, **Right-Click on one of the workspaces** e.g Animation. - From the context menu that opens, select **Delete**. The workspace is removed from the menu bar. - **Click on the Add Workspace** button. - Then from the menu that opens, **select General => [Workspace that was deleted previously]**. In this case it was Animation. - Notice that the **workspace is not added**. > This is happening in the default startup.
Added subscriber: @RKV-075
Added subscriber: @LukePoco
It looks similar to my problem (https://developer.blender.org/T66940) Did you imported old blender configuration? Is it possible to add Animation taks before delete it?
Added subscriber: @GavinScott
It works here for me on Windows 10. Can you try File->Defaults->Load Factory Settings and see if it behaves any differently?
@LukePoco I did not import old blender config.
@LukePoco @GavinScott I didn't get a chance to check your suggestions. Will do it in the evening today and let you know.
> In #67005#723091, @LukePoco wrote: > It looks similar to my problem (https://developer.blender.org/T66940) Did you imported old blender configuration? Is it possible to add Animation taks before delete it? @LukePoco I did not import old blender config. @LukePoco @GavinScott I didn't get a chance to check your suggestions. Will do it in the evening today and let you know.
This issue was referenced by 1f1d302950
This issue was referenced by 1f1d302950044592b8812c022897abfc838580a4
Tried this again as per the suggestions and it didn't work.
However, after deleting the configurations folder of 2.80 and trying again it started working.
Tried this again as per the suggestions and it didn't work. However, after deleting the configurations folder of 2.80 and trying again it started working.
Brecht Van Lommel self-assigned this 2019-07-16 17:50:45 +02:00
5 Participants
Reference: blender/blender#67005
