Crash when playback preview rendering volume in cycles possibly due to overload #67076
6 Participants
Reference: blender/blender#67076
Graphics card: GeForce GTX 970/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.86
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-11 13:50, hash:
06312c6d2d
When I playback my smoke simulation in cycles preview rendered view it can't render the frames as fast as it needs to which leads to a crash.
blender.exe: EXCEPTION_ACCESS_VIOLATION at 0x00007FF7D69FXXXX (last digits are different every time)
Added subscriber: @McLP
Added subscriber: @dark999
this bug is not reproducible on OpenSUSe Tumbleweed linux CPU AMD FX8350, 16G ram, GPU Nvidia GTX690
System-Info_blender-2.80-af51988115d4.txt
i played simulation for more than 10 minute and it is not crash or error
.blend file was setting for CPU Cycles rendering, i test this file with GPU Cycles rendering, same result
Tomorrow I'll try it myself on more PCs and systems. my cpu is a little older (FX6300 iirc) but I think it may have something to do with windows.
or maybe some kind of hardware problem like ram or power supply or a bad overclock configuration if you use it
Added subscriber: @ZedDB
Let us know how it goes. (I can't reproduce this on my end either)
I'd wonder if it was a hardware problem since I don't have any other issues. but I can't reproduce on my laptop either. but it is neither a ram nor a vram problem, they are doing just fine. can I get blender to output a more detailed crash report?
You will have to compile blender yourself to get a debug build.
What CPU do you have? Does your CPU pass some stresstests?
my cpu/gpu/ram are passing stresstests (did prime95,FurMark,etc). when i run the blender_debug_gpu.cmd, the last lines are always similar to this (crash occurs when mapping memory (but not the first time, only later), always same address now):
Just to be sure, does this happen with the latest blender beta? https://builder.blender.org/download/
still happens on RC2
but it does not crash in debug mode, only in normal use. That's wierd.
Oh, it does, but it takes a lot more efford to overload.
another log... I needed to rotate the view to the following position and zoom in a bit to get a crash.
sorry for postig so many messages, i think i found another clue now - shortly before the crash, the frame rate goes up to about 20-60fps while it is not showing any new frames and before the crash it would at maximum be around 5-15 fps. edit: not only shortly before but sometimes a bit longer. but it does not crash at low fps.
btw, I just tried it with blender 2.80 (not rc) on my laptop (Lenovo X230, not the pc I first encountered it). still crashes.
Added subscriber: @iss
Changed status from 'Needs Developer To Reproduce' to: 'Confirmed'
I was able to reproduce this only in release build. I wasn't able to build smoke cache in debug
Added subscriber: @mont29
@iss would still be useful to have a minimal backtrace to identify in which part of the code it happens I guess?
Backtrace to crash:
Got this using RelWithDebInfo, in debug this file barely renders...
Added subscriber: @brecht
This should be fixed by
e6d0a43
