Assigning shortcut to Sequencer data is wrongly 'hooked' the Scene instead of Scene's VSE data
Confirmed, NormalPublicBUG
This error shows all the time when I right click on the viewscreen, and I have to right click and press ESC, so the message disappears and I keep working this way, right click, a message appears, ESC.
It suddenly started to happen and even deleting and downloading blender again, even with the other 2.8 version it happens.
Thank you, I love your work guys
Just trying to help
Operating system: Windows 10 Home, Core i7 - 7500U @ 2.70GHz, 8.00 GB RAM
Graphics card: AMD Radeon R7 M440 32GB, 4.00 Gbps
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
Please provide the exact Blender version and also the system-info.txt.
You can do that by going to the help menu. If you click on "Report a bug" the information about the Blender version should be filled out automatically. Also in the help menu you can save the System Info.
A screenshot which is showing the error message is also helpful.
Alessio Monti di Sopra (a.monti) lowered the priority of this task from 90 to 30.Jul 18 2019, 12:17 AM
Can you please attach a screenshot of the error message you get?
Does this also happens when you load the default settings?
Alessio, I just loaded the default setting and now it is working very well, thank you very much!
But unfortunately, it changed the way I used to work on blender, but I'll try to configure it again, this time without messing up hahaha
By the way, follow bellow the information about the problem I was experiencing, it might be helpful somehow (I had filled out this request before realizing that loading the default setting would work)
Sorry man, here it is the right information
Graphics card: AMD Radeon R5 M445 Series ATI Technologies Inc. 4.5.13541 Core Profile Context 24.20.13019.1008
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-11 13:50, hash: rB06312c6d2db8
It happens all the time when I right-click on the viewport, I've also tried on blender 2.8 beta, the same problem happens, and I have to press ESC after right-clicking. But when I hold shift or ctrl or alt + right-click it doesn't show the message.
Thanks a lot for helping me guys!!
Bastien Montagne (mont29) raised the priority of this task from 30 to 80.Jul 29 2019, 6:28 PM
Richard Antalik (ISS) changed the task status from Needs Information from Developers to Confirmed.Jan 3 2020, 6:41 AM
While this should be resolved by rBacd98599ffe4, I am still able to "reproduce":
  • Open new Video Editing template
  • assign shortcut ctrl+++++a to Timeline header -> View->Cache -> Show Cache
  • hit ctrl+++++a
Results in
Error: Traceback (most recent call last):
  File "C:\Users\John\Desktop\blender-2.82-56ef761381ec-windows64\2.82\scripts\startup\bl_operators\wm.py", line 349, in execute
    if context_path_validate(base, data_path) is Ellipsis:
  File "C:\Users\John\Desktop\blender-2.82-56ef761381ec-windows64\2.82\scripts\startup\bl_operators\wm.py", line 84, in context_path_validate
    value = eval("context.%s" % data_path) if data_path else Ellipsis
  File "<string>", line 1, in <module>
AttributeError: 'Scene' object has no attribute 'show_cache'
while menu is drawn by
class SEQUENCER_MT_view_cache(Menu):
    bl_label = "Cache"
    def draw(self, context):
        layout = self.layout
        ed = context.scene.sequence_editor
        layout.prop(ed, "show_cache")
Bastien Montagne (mont29) renamed this task from Blender 2.8 bug to Assigning shortcut to Sequencer data is wrongly 'hooked' the Scene instead of Scene's VSE data.Jan 20 2020, 5:53 PM
Bastien Montagne (mont29) changed the subtype of this task from "Report" to "Bug".
@Richard Antalik (ISS) rBacd98599ffe4 fixed a similar issue, but it did not affect the area at stake in this report.
