Please describe how to make add-on development more efficent (e.g. reloading) #67387
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
11 Participants
Reference: blender/blender-manual#67387
Problem
No clear documentation on how to setup an efficient development environment and reload an add-on during development, leading to slow and frustrating experiences by newer add-on developers.
Explanation
Imagine being a new add-on developer who just finished the Add-on Tutorial (https://docs.blender.org/manual/en/dev/advanced/scripting/addon_tutorial.html#intended-audience). You wrote a .py file and wonder, do I really need to add every .py file through
Preferences ‣ Add-ons ‣ Install…
?Edit ‣ Preferences ‣ File Paths ‣ Data ‣ Scripts
.Next, we realize you rather write "create blocks" as "Create Blockies", but wait, or add-on is already loaded. How do I reload the add-on? Do I really have to close Blender every time? With your Google skills (https:*blender.stackexchange.com/questions/2691/is-there-a-way-to-restart-a-modified-addon) you find that F8 should reload all add-ons... except it doesn't, because that's for 2.79. Luckily you read through the comments and realize you have to go through the painful process of searching for
F3 -> reload scripts -> enter
every time we need to reload a change. In the other answer you findbpy.ops.wm.addon_enable(module='your_module_name')
for in the Blender terminal, which might be slightly faster (just arrow-up -> enter). You continue for a while and started to make a multi-file add-on. Suddenly your code shortcut doesn't reload every change you make? After some experimenting you find out that only changes in__init__.py
are noticed, so you go to (https:*blender.chat/channel/python) and ask what is wrong (https:*blender.chat/channel/python?msg=fGEyJtjNZqfpApxQ5). Which doesn't solve your issue, so you dive in the code of ``bpy.ops.wm.addon_enable()and make an issue about it (https:*developer.blender.org/T66924). There, someone points out that actually
bpy.ops.script.reload()is the right code command, not
bpy.ops.wm.addon_enable(module='your_module_name')`F3 -> reload scripts -> enter
or the correct code linebpy.ops.script.reload()
.You hear you can set a keyboard shortcut for reload, so you find an image about it (https:*devtalk.blender.org/t/reload-button-in-2-8/1708). The image there doesn't tell you how to set the keyboard shortcut and
Preferences -> Keymap -> Search -> "reload script"
doesn't show up anything. So you Google now: "Blender 2.8 how to add a new shortcut", which shows only "Blender 2.8 changed these shortcuts!", so you add "your own", only to find this page saying it has not been implemented yet (https:*blender.stackexchange.com/questions/124475/blender-2-8-how-to-add-a-new-shortcut). Then in a 2.79 YouTube video you find you first have to collapse a line (e.g.Screen -> Global
where a buttonAdd New
shows up.Please include in the docs how to set a keyboard shortcut for add-on reloading:
Preferences -> Keymap -> Screen -> Screen (Global) -> Add New -> collapse -> see image
.Please also include (a link to) how to setup an IDE to develop your add-ons with.
Add-on reloading
Please also include that the beginning of your file needs a structure like this if you want to reload add-ons:
Request
By reading this, you might have noticed that getting into efficient Blender add-on development is quite frustrating with the current documentation. Please make an extra page about how to setup you add-on development environment, using the bullet points above, here: https://docs.blender.org/manual/en/dev/advanced/scripting/addon_tutorial.html#intended-audience
Added subscriber: @NumesSanguis-3
Please describe how to make add-on development more efficentto Please describe how to make add-on development more efficent (e.g. reloading)Added subscriber: @JacquesLucke
Just a quick note, addon reloading can also be done differently. This Visual Studio code extension does the reloading automatically: https://marketplace.visualstudio.com/items?itemName=JacquesLucke.blender-development
Personally, I'm not really a big fan of the reloading code you mention, but yeah, it is used in many addons...
Added subscriber: @JosephDavies
Added subscriber: @dr.sybren
The reload code is incorrect. The return value of
importlib.reload()
should be assigned to the local name of the reloaded module, oraddon_props
andaddon_panel
will still refer to the old module.This style of addon reloading code fixes that, and as an added benefit it is also compatible with MyPy type checking:
By not checking the name "bpy" but one of the addon's imported modules, it's also possible to just
import bpy
like any other module, and have the PEP 8 suggested order of "standard library", "third party", "own code" in the imports.The MyPy compatibility comes from having the import first, and the reload later. This makes it possible to parse the file top-to-bottom. I suspect that some IDEs may also prefer this order.
Added subscriber: @zgorg
This comment was removed by @zgorg
plz watch this https://youtu.be/QrNr4U17v3w
Added subscriber: @bunnybones
I have the same gripes. To make matters worse, running
causes blender to crash for me. I'll keep looking for that better workflow as well. Hang in there!Added subscriber: @jmu
Added subscriber: @doppioslash
Added subscriber: @vromance
I am exploring reinstalling addons (zipping the directory and re install) automatically within Blender with one hotkey (ctrl shift R), while keeping track of several 'work in progress' directories in the user preferences (just check/uncheck which ones should be reinstalled when you switch projects). I know this is not the best solution, but the goal would be to mimic a real (re)install, similar to any user who receives your add-on zipfile and installs it in a fresh Blender install. The reloading / removing modules should definitely be revised and improved, and there are surely some other things that should be handled... But it works pretty well for me so far. (famous last words).
https://github.com/josvromans/blender_reinstall_addons
Added subscriber: @drewp
Added subscriber: @hyyou
