object rotate python API #67393
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#67393
Operating system: Windows 10
Graphics card: RTX 2060
Broken: 2.80 RC 2
Python API does not rotate camera around 3d cursor but around local camera axis. See this screendump:
Run the following script: rotatebug.py
Added subscriber: @jdk
Added subscriber: @dr.sybren
I can confirm that the attached code rotates the camera around its own origin, rather than the 3D cursor.
Generally it's better to not use operators to perform transformations, though. Rotating around an arbitrary point can be done without moving the 3D cursor by multiplying the object's matrix. This is also generally faster than relying on operators, and easier to control (you don't have to change the active object, don't have to change the 3D cursor, etc.).
Added subscriber: @ideasman42
I'm closing this as Known Issue, as the operators are working as designed and are hard to change without influencing many other areas of Blender.
As I said my earlier comment, changing the object's matrix is a better way to rotate; it's more reliable, and it doesn't make users loose their 3D cursor position.
